Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Rear air port for release of too high suction
Is there a way to gain access to the port area? I think something is stuck in there.
    Problem Solver:
  • 7 Answers
You have to open the entire mid section of the vacuum. There is about 8-10 screws to remove. I would inspect for clogs in all tube sections prior to opening. I've opened my vacuum many times it's not terribily difficult just be careful to not disturb the wire routes or pinch them when closing the vacuum back up.
Posted on Dec 05, 2008
How to remove CLOG Riccar RAD.7 vacuum?
There is a clean out port on the back on the lower portion. Remove two screws to remove the cover to gain access to the air path from the floor to the bag. If this doesn't solve it you may have to remove the screws on the bottom which allow you to remove the cover of the nozzle assembly. There is a cover that goes from the floor to the direct air motor. Remove the screws to remove this cover which gains access to the air path and fan of the direct air motor. It's possible you may need to remove the direct air motor to clean out the fan if it has something stuck in there. This is not a job for the average person but if you are very mechanical you should be able to do it. If in doubt take it to your dealer. It is not very expensive to have done.
Apr 22, 2016 | Riccar Radiance Upright Vacuum Cleaner...
My machine has suction at the port where the canister fits on the base, but immediately sounds clogged with no (or very little) suction going to wand or floor. All filters cleaned (accesible) and no clogs...
I will list the spots to check this vacuum for clogs. First see the first diagram I uploaded.
  1. First thing is to remove the canister.
  2. Then you will see in the diagram "A." Press that button and pull the hose up and check for blockages. Make sure to check for light through the hose to guarantee no blockages.
  3. Now tilt the vacuum forward and pull out the U Bend Airway and inspect it as well (3rd pic in diagram)
  4. Now squeeze the valve release catches to remove the airway and inspect the valve for blockages. (4th pic in diagram)
  1. The diagram above is the pre motor filter many forget to check.
  2. Press the filter release catch and pull the filter housing out.
  3. Remove the filter.
  4. Wash real good and let dry completely.
  • Now the one thing that tends to go bad on these vacuums is the automatic air flow adjuster. When the vacuum is upright the pathway for suction is automatically on the wand. After some good use the little disk in there snaps and the air flow stays restricted in what ever position the vacuum is in. I have contacted Dyson a few other time and they do not sell this part. It is a factory fix only or I would give you the instructions to do it yourself.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have cleaned the canister, the filter, everything....and yet the dual blades won't turn and there is barely any suction. HELP?
the suction part must be a clog in between the suction port into the unit check that and if they dont turn maybe belt broke or something is stuck
Feb 15, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
Vacuum does not have good suction. We've cleaned
sometimes debris can still be hidden in odd places. if you have access to compressied air you might carefully us it to blow out all the passageways that the air travels from the brush to the dirt holding area. make sure you dont have a filter that you missed when you replaced them. use low pressure air to blow out the system as high pressre air might damage a part of the the motor running at the normal speed? if not you might try to find out why and fix that as well. as always never worksk on a vacuum that is plegged in. good luck.
May 16, 2010 | Dyson DC07 All Floors Bagless Upright...
I just vacuumed up a sock and my vacuum stopped working
The sock could have caught in the roller area and / or plugged the suction hose. most likely you will need to gain access to the roller area to loacte the sock. good luck!
Oct 28, 2009 | Kenmore Vacuums
Royal vacuum has no suction
If a vacuum has not suction then there has to be something plugged up in the port. You will probably have to remove the bottom. Either with a bag or bagless, find the suction port and usually it's plugged with all kinds of stuff. Sometimes if you have access to compressed air you could blow it out from where the bag hooks up or if bagless where it empties into the container. It's not that unusual for it to plug up. My parents have old old old carpet from I think the 70's, (The shag type that you can use a rake with) and there vacuum is always getting plugged up. Good luck.
Jul 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
Bissell 7950
appears that you may have all the belts in place but the beater brush is jammed and it can't spin.. the jam may also be blocking the vacuum port so that you don't get any suction to that area. I suggest you unplug the vac, then open the base section to gain access to the beater bar and check to make sure the brush can spin freely.. also check that the drive belt is properly seated on the shaft and that there are no obstructions in the vacuum port.. hope this helps you..
Sep 21, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
42 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
