Question about Canon Office Equipment & Supplies
Need service/user manual for Canon Imageclass D420
Prints horizonal lines in the printed document
SOURCE: Canon Pixma 210
Had exactly the same problem. Software reinstallation fixed it right away. Hope that works for you!
Posted on May 05, 2008
jonb3838
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Posted on Feb 12, 2009
fotobean
  • 103 Answers
SOURCE: colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Posted on Feb 21, 2009
niquose
  • 198 Answers
SOURCE: Need user manual and/or service manual for Canon imageCLASS C2100
here you go...this printer model is known as cp660 on other regions (based on their Web site).
http://printer1.blogspot.com/2008/03/canon-cp660-service-manual.html
hope this helps.
Posted on Jun 24, 2009
  • 62 Answers
SOURCE: Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Posted on Feb 13, 2010
Red light is blinking cant take print
  1. Canon imageCLASS MF3010 Manual
    https://www.manualowl.com/.../Canon/imageCLASS-MF3010/Manual/11...Manuals and user guide free PDF downloads for Canon imageCLASS MF3010.
Jul 21, 2015 | Canon ImageCLASS MF3010
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
Dell 420 instructions
Need more info, Norman.
1) User Guide, or Service Manual?
2) Laptop? Dell 420? Would that be the Dell Latitude D420?
Going with Dell Latitude D420;
http://support.dell.com/support/edocs/systems/latd420/en/index.htm
User Manual = User's Guide
Click on the blue - View - to the right of User's Guide
Service Manual:
Click on the blue - View - to the right of Service Manual
Not the correct computer? Then look for the white Service Tag,
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&docid=267748&doclang=en&l=en&s=dhs
Need the letter/number under the bar code.
(DO NOT post the Windows product key )
Post back in a Comment.
Regards,
joecoolvette
Aug 03, 2012 | Computers & Internet
Exposure problem
If internally generated prints are good, but copied documents are bad then your scanner needs cleaning. This can be found in the document feeder section where the light scans across the paper. If both copied and internally generated prints are bad, then chance are, your toner/drum catridge has run out.
Jun 18, 2010 | Canon D320 imageCLASS Digital Copier
Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon imageclass 2200 prints dark line on documents being copied
cleen slis glass in dock feeder open the door on the top windex will work
Apr 22, 2009 | Office Equipment & Supplies
hope this helps.
Mar 05, 2009 | Canon imageCLASS C2100 Laser Printer
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
239 people viewed this question
old marine
old marine
