Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Filters how do i clean the filters
  • Official Brand Answer
  • 2,572 Answers
Step by step filter washing instructions can be found in the support section of our website.
Please visit http://support.dyson.co.uk/support/dc05/dc05-standard/how-to-use-your-dyson-vacuum/wash-the-filter/filter-washing-video to learn how to wash your filter and for more information on maintaining your DC05.
If you need further assistance please call our Helpline free at 0800 298 0298.
Best wishes,
Jessica
Posted on Feb 16, 2012
How I clean exhaust filter
Here is what the owners manual of your unit lists to clean the exhaust filter.
Cleaning the exhaust filter
Open and remove the filter grill. (Fig. 4)
Remove the filter and shake out debris. (Fig. 5)
Rinse the filter in water if necessary. Let it dry before placing it
back into cleaner. (Fig. 6)
Replace filter grill.
Apr 03, 2016 | Eureka Rally 2 Canister Vacuum with...
Bissel carpet cleaner not sucking up dirty water why ?
Sounds like a clogged filter. Try cleaning the Flow Indicator Filter (turn Flow Indicator cap counter-clockwise to remove it, lift out rotor and filter under it. Clean filter and reinstall in reverse order); Check and Lint filter on the Heater tank Cap. All filters are recommended to be cleaned after each use. Bissell Consumer Care number is 1-800-237-7691
Nov 24, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
The upholstery tool on my bissell lift off deep cleaner sprays bUT doesn't suction?
The lint filter on the water tank cover may be the reason for that. Try cleaning the Filters. Clean the Flow Indicator Filter: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. The Water Tank Filter looks like a screen on the underneath the front area of the cover. It's held in with tension and just pulls out. Clean it and replace it. Hope that Helped but if it didn't call the consumer care at 1-800-237-7691
Sep 14, 2015 | Bissell Vacuums
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Why is there no suction or extration of wateron my bissell pro heat pet ?
Your filters may be clogged. The User Guide states that filters are to cleaned after each use. To clean them Turn the Flow Indicator Cap counter-clockwise and remove it. Lift out the rotor and filter. Clean filter and reinstall in reverse order. There is also a Lint Filter on the Hot Water Tank Cap that you should clean as well. When these get clogged they seem to do funny things. Hope I helped.
Jul 05, 2015 | Bissell Vacuums
How to clean filter
The filter is usually replaced or washed.
Mar 03, 2015 | Filter Vacuums
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
Has no suction
1. Remove dust collector compartment/s. Look for any filters, remove and clean. (Make sure you DO NOT clean filters with water.) Take filter/s outside and "slap" them against a flat surface. (Filter will be very messy to clean)
2. Replace all filters and compartments.
3. Also try using a wire hanger and try to reach as far down the hose as possible to remove any obstruction/s.
Note: Clean vacuum filters frequently to ensure proper suction.
Feb 10, 2011 | Bissell 3920 Bagless Upright Vacuum
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
How do I clean the filters
Generic problem for all Vacuums
How do I clean the
How do I clean the filters?
Comment by Avonb, posted on Apr 22, 2008 I have a Bagless twin clean, thought I was cleaning the filters but apparently not, the manual is very vague
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the Model # or Brand name, it is a good idea that you can vacuum of the filters, if you have a blower – you can blow off the dirt from the filters, some filters are washable and you can clean them by washing them and letting them dry completely before you re-install the filters. Idea? If you have an old paint brush, that is ideal to clean off HEPA filters or cartridge filters or use a blower to clean off the dirt. You need to be the best judge on how to clean the filters. You can check the company’s website for the brand name such as:
http://www.hoover.com ---- example given
Don – The Vac Man
Apr 22, 2008 | Vacuums
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
160 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
