Question about Sharp 13VT-N100 Combo
Power supply zapped
I have my tv/vcr overseas where they use 220V and 50Hz. My son plugged it in and it blew up. Is there some possibility that it has an inner fuse that blew or do I have to throw away the whole machine?
    President:
  • 3,130 Answers
It could have blew a fuse but if you heard it or somethiung blow its probably trash. You may want to have it looked at first though
Posted on Aug 16, 2006
My relative send me a luxor tv its 50hrz..here in the philippines we use 60hrz.,is it possible and safe
is there no small slide switch at the back of the tv
10 volt difference
may need an converter to make up 10 volts
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
read this information on the 50 and 60 hrz
Difference between 50Hz and 60Hz frequency
Nov 02, 2016 | Luxor Televison & Video
How can i go from a 4 prong 220v outlet generator to a 3 prong 220v plug for oversea appliances
Last time I was in europe, they were using AC current at 50 cycles.If you check the specs. on your genset I think you will find it is a 60 cycle AC generator. If I am correct,you can slow down the genset to get the 50 cycles needed but then you would need to adjust the field excitation to get the voltage back up. Then change the outlet to a european type that you should be able locate on line or through an electrical supply house.
Jul 13, 2012 | Coleman Powermate Premium Plus 6250W...
Is there a replacement fuse or power supply for Husqvarna Viking 990??
check with husqvarna customer service about the fuse or power supply
Feb 27, 2012 | Husqvarna Sewing Machines
Can this unit be plugged into a 220v power supply overseas? The manual says it accommodates 100v-240v.
Yes! If you look on the back it should say the voltage ratings. Beside that UK voltages can be as low as 220 at times and in some areas!
Nov 30, 2010 | Samsung SV5000W VHS VCR
Hi, Will the krell kav 500i work on 220v 50hz supply? Thanks
If it has a voltage selector for 220v, once configured it will work just fine Being electronic instead of mechanical the power frequency won't affect it. If it doesn't have a voltage selctor, don't plug it into 220.
Dec 26, 2009 | Krell Audio Players & Recorders
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Plugged my US made PC into a 220v outlet!
Hi
You need to change power supply unit. You can find a guide with screenshots here
May 03, 2009 | E-Machines eMachines Desktop PC
Tv wont turn on
The surge most likely shorted the horizontal output transistor, and with that being shorted, it causes the power supply to "sing" from the increased load it is seeing. Unfortunately, it would probably cost near $100 to repair unless you were able to do it yourself.
Dec 30, 2007 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Sharp 13VT-N100 Combo Logo
63 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
