Question about Brother Sewing Machines
How do i thread a ja 28 model
How do i thread a ja 28 deluxe model? I am not sure I am threading it right. Also it is bunching up on the underside of the fabric I am trying to sew, string keeps breaking etc.
5 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: Bicor vx1005 ...thread keeps bunching
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
bargainbox
  • 1388 Answers
SOURCE: Thread bunches on bottom of fabric
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
Set Top Tesion to 4 ....then....
TOP THREAD TENSION:
projects).
BOBBIN TENSION:
TOP LOADER:
FINISHING UP
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on May 10, 2008
mohammed387
  • 1952 Answers
SOURCE: my needle thread keeps bunching and llooping on
If you getting loops on the bottom of your material, you need to re-thread the top of your machine. I say this because it is very rare when you will have to adjust the bobbin tension. But if you must, looking straight down at the bobbin as a clock- at 6:00 is the bobbin tension adjustment- lefty lucy, righty tighty. Hope this helps.
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correct
There is no standard tension for any machine to be set at. They start at four when they are brand new, however, after years and years the springs become compressed. You could start at four and then play around with it from there. If you are getting loops underneath the material, you are threading the machine incorrectly.
Posted on Jul 15, 2009
bargainbox
  • 1388 Answers
SOURCE: on underside of material thread is loose and not catching
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
Posted on Sep 02, 2009
  • 9 Answers
SOURCE: the tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Posted on Apr 06, 2010
Thread on the bottom side of stitch is all bunched up
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Oct 09, 2012 | Sewing Machines
TENSION IS NOT RIGHT IT IS LEAVING A BUNCH OF THREAD ON THE UNDERSIDE
Hi there.
When ever you have bunching thread like that it can be a few things.
1. Not properly drawing the threads back under the foot when beginning a seam (grasp both and gently draw them to the back of the machine when starting.)
2. Your feed dogs could be down or not adjusted well.
3. Your top tension is too loose for the fabric or top thread is not threaded properly. (this is usually the problem)
4. bad or wrong needle for the fabric.
Thread can be an issue as well, it does age and get frayed causing problems.
First make sure you test on a scrap of the same fabric. Tighten your upper tension to see if that helps. If not RAISE your pressure foot and read thread the top thread making sure the thread sits in the uptake lever. Try again on your scrap.
Good luck.
Mar 13, 2011 | Janome Sewing Machines
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
Sewing machine grabs fabric and won't let go
I dont think the top thread spool feed is the problem, I sounds like the upper thread tension is set at too low a number. Normally on that model it should be set at 3 to 6.
May 06, 2010 | Sewing Machines
The tread gets all bunched up on the underside of
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
Oct 06, 2009 | Sewing Machines
Bunching thread
make sure you have it threaded properly.
Jun 05, 2009 | Brother CS-80
Thread from bobin doesn`t leave smooth sewing on bottom of fabric
hi make sure pressure foot is raised before you start to thread machine ortherwise thread will not slide between tension discs this will cause bunching underside of fabric ...good idea to replace needle good luck
mary h
Jan 05, 2009 | Husqvarna Viking 1
I have a White 3300 embroidery machine not catching bobbin thread
Try putting a new sewing machine needle in and make sure the eye of the needle is facing the right way. Needles look like they should go just anyway, but if they aren't in right, it could cause the problem you are having.
Jan 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread is bunching up on the bobbin side
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
I think you might be using the wrong size needle, or thread for the material you are sewing... but the site might have a few more options.
Good luck and Happy sewing!
Dec 13, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
125 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
