Question about Kenwood KDC-4019 CD Player
No power to Kenwood KDC-4019 faceplate
I have checked the fuses and connections to the radio and cannot get power to my faceplate.
There is power to the receiver itself as i can eject cd's, but i cannot get sound because the faceplate will not turn on. I recently had a lot of wiring work done none of which should have affected the stereo.
The battery was disconnected for about two weeks while the work was being done, I also had the faceplate detached during that time as well.
I have tried pressing the reset button and a combination of other bottons as well, with no sucess.
Just wondering if there is something else I should try or if the faceplate is just dead. And if that's the case then would a new faceplate fix the problem or would I need a whole new receiver as well?
Thank You Very Much
  • salamillo Feb 20, 2009
    Yes I have the same problem but my car stereo is a Kenwood KMD-X92
    Mini Disc,I will like to know what was the solution to this problem.
    President:
  • 624 Answers
It sounds like the stereo does not have the "ACC" voltage. It could have blown a fuse. The "ACC" voltage goes to the red wire on the harness and you get that voltage turned on only when the ignition is turned on in the car.
The symptom of the disc ejecting and nothing else works is an indication that only the constant voltage for the yellow wire is connected. Check the voltage on the red wire with the car turned on, if you have that 12 volts at the red wire, then you need the radio serviced.
It is not very likely that the faceplate has gone bad. Just because the radio will not turn on is not an indication that the faceplate is bad. It could be a voltage regulator in the radio or a circuit trace is blown, or almost anything else. There are many reasons that the radio would have the problems you describe and it can only be found out for certain by troubleshooting the radio on a test bench with the proper tools. If you have a multimeter and a power supply I can guide you thru troubleshooting the radio and even email you the service manual in PDF format if you would like to take a crack at it yourself.
Let me know how you want to proceed.
Dave
Posted on Oct 31, 2008
No power on my Kenwood kdc mp 4032
I would use a test light or multimeter and see if you have system voltage at the back of the deck on the power wires. This will tell you whether the problem is with the Kenwood or the wiring and components coming to it. Remember the car has a radio fuse too
Jun 05, 2016 | Kenwood KDC-MP4032 CD Player
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
Kdc-x993 - power to head, but no display when face is installed. the cd eject button is blinking but when i install the face, the display will not come up.
you dont have power to the ignition wire on the radio(red wire) the yellow wire should have constant power(12 volt) check your radio fuse in the fuse block on the car or on the red wire itself
Jan 23, 2010 | Kenwood Car Audio & Video
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Kenwood kdc-mp232 not turning on
check your connections. i believe only the standby wire is connected.. or the built in amplifier detects a short on the speaker wires.
Jul 18, 2008 | Kenwood KDC-MP232 CD Player
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Dead Kenwood KDC-128 CD Player Is there a "reset"
KENWOOD MADE TWO DIFFERENT EDITION FOR THIS AND SOME OTHER MODELS. YOUR WILL NEED TO CHECK THE SERIAL NUMBER AND YOU CAN CHECK WITH PACPARTS AT pacparts.com THEY WILL GET THE RIGHT ONE FOR YOU
Dec 13, 2006 | Kenwood KDC-128 CD Player
Kenwood KDC-4019 CD Player Logo
248 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
