Question about Gateway (M520HD100G) Hard Drive
Xp home installation
I want to put xp home on my gateway harddrive (vista basic preinstalled) - my xp home disc does not find my hard drive
  • 1,996 Answers
You need to have installed drivers for xp for that hard drive. Without them it won't load.
You can go to the Gateway site and enter your serial number to see the original configuration of your system, get the names of the hardware installed on it, and look for drivers for xp for all of that hardware.
Please see this article and follow the links at the end to make sure you have all the drivers needed for an xp installation. Downgrade vista to xp
Also an excellent tutorial for updating drivers here and a source of drivers here
Posted on Apr 02, 2009
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Is it possible to move Vista from one computer to another without the disc? I have a product key for the Vista that was installed. The original OS was XP and Vista was purchased and installed. I got this...
It can be done if:
1) the i386 directory was installed on the first PC
2) the first machine is being scrapped (must happen or you violate the Microsoft EULA)
3) you can burn a copy of the Vista i386 directory
There are additional things to do to complete the process, but the answers to the above will determine if it can be done.
Aug 03, 2011 | Computers & Internet
How do I setup a dual boot for a PC with Vista and XP? I want XP to start automatically.My laptop is a Toshiba Satellite L355-S7915 that had Vista Home Basic preinstalled.
The first thing you need to do is repartition the hard drive. This will effectively erase the drive because partitions run below the OS level.
You create two partitions and then you can load each OS to its own partition. When the box boots you choose the OS you want to start and thats it...I think if you put the preferred OS in the first partition it will load that one by default.
You need both OS disks to do this so make sure your factory Vista disk works.
Mar 07, 2010 | Computers & Internet
My Hard drive can't read the disc's I put in to install
Are the disc's compatible with Vista? I have had Vista fail to read older windows series discs
Aug 19, 2009 | Microsoft Windows Vista Home Basic Edition...
I have Windows Vista Home edition installed in My Compaq Presario 700. I have been experiencing a slow down in the performance from last 3 days. So tried to install Windows XP. But It immediately shows...
You need to format the drive so back up all docs etc that you want to keep and then boot from the install disc (make sure it's an install disc NOT an upgrade) then you will see an option to format and partition the drive. The problem is that Vista is an upgrade from xp, and it won't allow you to downgrade.
Jun 30, 2009 | Compaq Presario 700 470024-192 Notebook
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista., and, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Oct 26, 2008 | Gateway 4525GZ Notebook
First off, you don't sound dumb, nobody is born computer literate. It's one thing to learn how to use computers, it's another when it comes to loading or working on them. Don't worry about it reading upgrade from 98 or 2000, Vista wasn't around when they packaged these, and Vista to XP is fine. I use XP Pro, I find that it's better than XP Home for my needs. Pro or Home will work fine for you, don't get the XP basic, the Home and Pro have better features. Also, you just need to purchase A Windows XP disc, and not a disc from Gateway or Gateway disc. Windows XP is sold at Walmart, Bestbuy, or Circuit City. After the install you will need to go to Gateway's support site and download any drivers that you need, I'll list the link for it bellow. You can find which drivers you need in the device manager, the devices with yellow question marks need drivers. If you have any problems with any of this get back to me. Thanks for the compliment on the pic, most people don't get it, especially the younger crowd on here.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
What is this
if you are doing a clean XP install the CD will ask if you if you want to change your partitions.Afterwards it will automatically format the hard drive.Some of the OS discs dont come with drivers you will have to hunt for them on the internet.If you are using a restore disc copyied from a working machine it should have generic drivers already loaded in the disc.
Mar 12, 2008 | Computers & Internet
Computers & Internet Logo
216 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
