Question about Brother MFC 210C All-In-One InkJet Printer
Brother mfc 215c machine error 4f
It gave me maintenace machine error 4f
SOURCE: brother mfc-215c unable to clean?
What is machine error 26?
Posted on Dec 13, 2007
  • 526 Answers
SOURCE: MFC 215C, mfc 215c erorr 46
most likely your flush box is full of ink, the pads will need to be replaced by a service center.
Posted on Apr 20, 2009
pineworks
  • 4041 Answers
SOURCE: Machine Error 46
Hi Error 46.Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
All The Best: Pineworks
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Feb 18, 2010
  • 142 Answers
SOURCE: Brother MFC-215C installation software for ubuntu
Yes, you are in luck. Brother provides great support for Linux users.
Visit their site to learn about all their offerings:
If you have the MFC-215C printer,
then please use the MFC-210C driver.
Posted on Mar 05, 2010
How do you repair a 4F error message for Brother MFC 2550CW
machine error '4F' indicates print head or the PH PCB is faulty.
Mar 16, 2014 | Brother MFC-J410W Wireless Compact...
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
Mar 14, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Hi there
Feb 18, 2010 | Brother MFC-440CN InkJet Printer
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
I cant get my printer to clean or print keeps saying unable to print, please help
verifiqure se da algum erro
se der o erro:machine error xxx
faça o seguinte:
May 15, 2009 | Brother MFC-215C All-In-One InkJet Printer
Unable to Init - Machine error 4f
ok please try this
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Jan 09, 2009 | Brother MFC-425CN Multi-Function Center...
Brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
Oct 01, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
Unable to print mcf-215
plz press menu then start-bk-copy then fourtimes arrow up quickly after another. machine turns to maintanence mode. press start bk copy: what two digit error code does the machine display?
If it starts with a 4 you do need a new printhead!
Mar 28, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
365 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
