Question about Dryers
Need a blower wheel for crosley model #CDE-8000GBL
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a Crosley CDE 7000 dryer that stopped heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 06, 2010
heatman101
  • 43501 Answers
SOURCE: Crosley Clothers Dryer Model Number CDE/CDG22B8
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
heatman101
  • 43501 Answers
SOURCE: On a model CDE-20T8, I
Take it back apart and look around the new wheel... you should be able to see where it ia hitting and make an adjustment.... also before totally buttoning that thing up...see if you can run it a bit to see if it is quiet...
heatman101
Posted on Dec 05, 2010
Where to buy heating element for crosley CDE-8000GWC?
CDE8000GWC is not a Norge built Crosley dryer. The GWC is something else.
Mar 02, 2013 | Dryers
Crosley dryer CDE-8000GWC
Use a putty knife to release clips so you can raise the top ans swing it to the back. Then take the screws out to get the front panel off.
Once yall get the front off and the drum out the innards look like this;
Note: You cannot work from the backside of this one. You probably already now this. Main failures on these? Blower wheel wobbles, causing overheating fuse blows dryer is dead. Easy fix.
Dec 30, 2012 | Dryers
Crosley dryer will not turn on - worked fine one day and now will not work - suspect electrical switch but which one?
The thing that kills these dryers is lint and bad blower wheel. The lint causes excess heat in these dryers and that melts the blower wheel hub and it begins to slip. This makes the clothes take twice as long to dry and eventually trips the small thermal fuse mounted beside the heating element. themobilian_594.jpgthemobilian_595.jpg
Go ahead and remove the front panelthemobilian_596.jpgthemobilian_597.jpg More HERE
Dec 28, 2010 | Crosley Dryers
Crosley Clothers Dryer Model Number CDE/CDG22B8 will not heat up
heatman101
Oct 16, 2010 | Crosley CDE6000 Electric Dryer
heatman101
Apr 06, 2010 | Crosley Dryers
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
I have a crosley CDE/CDG7500 dryer wont turn on.
not realy a safe thing to do sorry, it may be only the door switches playing up on you,,
Oct 25, 2009 | Dryers
Dryer
Check the blower wheel and filter housing then replace the fuse which mounts on the heater chamber right next to the heatter, the same screw which holds down the heater holds the fuse to the side of the heater.
Dec 26, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
Top Dryers Experts
