Question about Refrigerators
Polar spray ice maker cb920 manual
Not making ice
  • 35 Answers
SOURCE: Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Posted on Jun 07, 2009
ndguy2481
  • 251 Answers
SOURCE: ice maker spraying water and freezes on foods
if u open the front of ur ice maker where there is a plastic cover it pops off there is a screw under that cover and u just need to turn the screw down and then see if that solve the problems if not please get back to me Looking to help u Shaun
Posted on Nov 15, 2008
carldc3
  • 82 Answers
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
Posted on Jan 05, 2009
stephanos18
  • 144 Answers
SOURCE: ice maker was making ice now water seems to be
Have you changed the water filter as this regulates water pressure to the icemaker? is there ice left/stuck in the maker leaving the water no place to go (normally caused when the icemakers element dies)? If so you need a new freezer Ice maker unit. this unit is plug in and only three screws holding it in so this is the easy fix, but not that cheap. cheers
Posted on Mar 26, 2009
  • 72 Answers
SOURCE: Maytag side by side freezer, the ice maker is
check for a piece of ice in the fill tube
Ice maker is not making ice. what could be the problem?
The two most common things that happen: the ice piles up too high, which pushes up the bar that tells it the bin is full and stop making ice. OR the ice sticks to the ice cube maker. If the ice pile is too high, knock it down or empty the bin. If the ice is sticking to the cube maker, try melting it and then spraying it with a non stick spray. Sometimes the water supply line is clogged, but that is not usually the problem.
Feb 28, 2015 | Refrigerators
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
Polar Ice maker says low water level when full of water
Replace the motor. During the cycle of the unit if the water flow circuit does not scence flow, the unit faults with a low water indication
Jun 22, 2010 | Polar PIM15W Ice Cream Maker
My ice maker MAKES the ice but doesn't dispense it.
yes. completely warm up the ice maker with a blow dryer until the metal is all dry then spray it with the cooking spray called pam. just regular pam, no other. this will lubricate everything and it will work like a charm. rememer tho it can take up to 24 hours before it will make ice again.
Aug 16, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
