Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
HOW TO MAKE MY HP LASERJET M155 PRINTER SCAN A DOCUMENT
dumbtrucker
  • 102 Answers
SOURCE: Can an HP Photosmart C4180 Printer scan a document to a computer?
You should have recieved software with the printer to do this, Look in the Hewlett-packard folder in the programs menu. It might be listed as HP Director. From there you should choose scan to as the option, one of the choices should be "to Fax".
Posted on Mar 23, 2009
  • 19 Answers
SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Posted on Jun 18, 2009
  • 102 Answers
SOURCE: multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Posted on Jul 04, 2009
  • 141 Answers
SOURCE: Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Posted on Aug 04, 2009
  • 31 Answers
SOURCE: How do I scan a document on a HP Laserjet m1522nf...
install full software, download from www.hp.com
Posted on Aug 10, 2010
From computer How can i scan document from HP LaserJet M3035 MFP
From the search I did that printer is not an all in one and does not hacv a scanner function
Feb 13, 2016 | HP Office Equipment & Supplies
1) whether the scanned document from this multifunction hp laserjet printer be saved in PDF format. 2) whether continous scanned pages be saved as one file/document.
The answer is yes to both questions. Follow the instructions below:-
Go to Adobe Acrobat. Click on FILE. Click on CREATE PDF. Click on FROM SCANNER. Click on SCAN. You should now be scanning your first page, after completing it you will be asked if you want to scan any more pages or close. Select to scan more pages till finished. You can also select to have Acrobat do an OCR after the scan which will allow you to search the document. To do this, click on DOCUMENT, click on RECOGNISE TEXT USING OCR and click on START
May 10, 2011 | HP LaserJet M1005 Printer
How to scan a document using hp laser jet?
Hi!
You can follow the linkd follow below, it will detail you how to scan document using HP Laser Jet:
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?locale=de_DE&taskId=115&prodSeriesId=378052&prodTypeId=18972&objectID=c00063830
http://www.ehow.com/how_6939172_scan-document-hp-laserjet-3200.html
Hope this helps.
Apr 18, 2011 | HP Laserjet M1319F Laser Multifunction...
I cannot scan a few pages and save them all in one file. so i have to scan every page and save it as a page. Printer HP LaserJet M2727nf
If you use the HP Solution Center and tell it to scan a document, after each page you need to place the next page on the scanner and then click on "Add Page". Also set the document type as PDF.
Dec 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
The printer shows that a document is inserted and the HP toolbox shows the printer status as having a document inserted..then use the scan button on pc to scan it
Oct 18, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
