Question about Philips 9P6044C 60" Rear Projection Television
Convergance/bowing I have a similar convergance problem as others have posted. The alignment is okay in the center but gets progressively worse towards the right and left edges using the convergance menu. Another problem is that it looks like a sideways hourglass, with the top and bottom edges bowed in a concave line. Is this just a case of replacing the STK convergance IC's, or is it something more? My IC's are STK392-110 with rather dry, but solid coverage of silicon goo btw. Haven't tried replacing the silicon yet.
  • Aaron namewithheld Oct 23, 2006
    Long time coming, but I just wanted to follow up on this. All in all it is fixed now. Thank you techman! I took the board in to a TV repair shop as I didn't feel to comfortable soldering the new IC's in. They found that one of the caps (220 I think) near it had also blown out. They replaced the cap and IC's with newer model STK392-180's and the TV is back in buisness again. $95 bucks out the door.
    The top slants a little to the right, but I think I just need to get in there and play with the manual controls some. The owner I inherited this from had moved them around a lot trying to fix the original problem. Thanks again for the input.
  • Philips Master
  • 3,459 Answers
You may have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Posted on Dec 20, 2008
    President:
  • 3,130 Answers
Most like tes thats all your going to have to replace + the silicon as if you dont thet wil not last as long as they should. Also you may have blow fuseable resistors next to the ICs make sure you check them as well.
Posted on Aug 16, 2006
On our rca hdtv model # R52WH77.. the tv is having like a 3d look on it and has a bow in the picture.. we bought the convergance repair kit from tvrepairworld.com and replaced the 2 parts it gives us.. ...
have you reset the convergence parameters after installing the kit to fix the option? Usually you will need to reset the defaults to get the outer edges back in alignment.
Aug 11, 2011 | RCA R52WM24 52" HDTV Projection Television
Hi i have a RCA P52937SG with the bowing of the screen
The problem may still be on the power supply board (one of the supplies may be missing and) when you unplug the supply both supplies go missing check the supply voltages and repost
Oct 14, 2009 | RCA P52937 52" Rear Projection Television
The green alignment lines are bowed up in the center of the screen where is the adjustment for this.
As far as I am aware, there is no adjustments on projection tvs. If there is on this one, it would be in the back behind rear cover. I believe that the convergance is controled by a "Y" board or system main board
Jun 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Red and blue convergence wont line up. What should i do.
convergance can be tricky and you should follow a manufacturers proceedure from a manual.
most specificaly start with the green H and V Linearity and center , then the Red and Blue
Projection TV's and Component Video RGB have their Horizontal and Vertical Sync signals on the Green Component..
There may be other reasons for their specific order of operations within a calabration proceedure such as your 'RGB convergance alignment'
Jun 16, 2009 | Hitachi 43FDX01B TV
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
Convergance,and distorted projection,colors will not align
These tv's have a separate convergence power supply that goes bad. This will cause the problem you are having. Depending on the age of your tv, the board may be available
Dec 07, 2008 | RCA P61927 61" Rear Projection Television
Convergence issue with blue
You need to replace the convergence Ics located up front behind the speaker grille numbers STK392-110 you can get replacements at the following link and they provide free tech support and instalation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Red convergence is bad.
Hi, you need to change the convergence ICs , STKs: and some resistors,low values; , after changing them, you will have to go into the service mode, to do some adjustments.that's it.
Nov 27, 2007 | Samsung HCN4226W 42" Rear Projection...
Philips 9P6044C 60" Rear Projection Television Logo
127 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
