Question about Oster 6700 Work Top Blender
Oster 6700 Blender
There is a gear, located at the top of the motor (sticks out of the base / case). This gear is what attaches to the bottom of the pitcher.
This gear is attached with a rubber type material to the motor shaft and the rubber has separated. I have contacted my local repair shop and they said Oster does not make the replacement part for this model.
Anyone else have this problem or know of a place I could get it repaired? This machine was working great before this and the wife really liked it.
Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives.
This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
Hope this might help Good Luck Loring
Posted on Oct 25, 2008
Same problem here. I can't find a repair part for the model 6700 series drive coupling when the rubber fails.
Posted on Dec 14, 2009
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Mar 19, 2009 | Oster Blenders
The red light on my blender keeps flashing but when i press any other buttons it just beeps twice and does nothing.
inside the jar ring base (turn it upside down) you will see little white tabby things in the slots, at least one of them has to be lined up with the 2 small grey contact points on the base of the blender.
I had this same problem!!
you can contact me at jureed@rochester.k12.mn.us
Julie
Jan 26, 2009 | Oster 6700 Work Top Blender
Power flashes but doesnt start
Yes, I know what it is. On the base of the blender jar (the plastic base) there are some "fingers" that must contact the base to allow operation to take place. Turn it upside down and look at the little plastic "fingers" around the outside periphery of the plastic base.
These fingers tend to break over time... mine only has two left right now, and it only works in one particular position as a result.
Rotate the blender jar one spot at a time until you are able to operate it "normally". I use it for margaritas, and it won't allow me to push the button for Frozen Drink unless the jar is in the right position.
I am going to try and find a replacement base (or entire blender jar) somewhere... or else I will finally have to retire my favorite blender of all time!
Dec 20, 2008 | Oster 6700 Work Top Blender
I have an Oster blender, model #6710, and the gear on the bottom of the pitcher where it sets in to the base has become unsaudered. I have only had the blender for 4 years. Is this unusual or normal...
The part that you need is available from Oster, and their phone number is 1-800-334-0759. Their standard warranty is 1-year, so you would probably have to pay for the part. 4 years is decent for a blender - if you replace the part, an Oster will most likely last many years longer. While it is not uncompletely unheard of for a blender blade assembly to come unhinged, it is statistically infrequent - the replacement part will most likely last as long or much longer.
May 05, 2008 | Hamilton Beach 57101 BlendMaster Work Top...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Oster 6700 Work Top Blender Logo
659 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Dave
Dave
Are you an Oster Blender Expert? Answer questions, earn points and help others
