Question about Malber TD700 Electric Dryer
Malber Company - Italy. Address
I need to purchase a starter capacitor for a Malber Tumble Dryer TD600 - 220 volts
Need to find a manual for Malber WD8008
Posted on Sep 02, 2011
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Hi, 1) I need a new Capacitor for my Malber WD 1000 washing machine. Can I order that from you ? How much is it ? 2) The dryer is not working - is there a way for me to troubleshoot to find out what...
hi there you say you need a new capacitor i would assume your motor is not operating .you should be able to get a new capacitor from any elec strore the size is stamped on the side ie 8uf 10 uf etc hope this helps
Jun 07, 2011 | Malber WD1000 Front Load Washer/Dryer
My dryer will not tumble
can be a couple of things.....1, belt could have slipped off, 2 your motor is faulty and not working at all - can you hear the motor working or humming?, 3 the device know as the starter capacitor (basically acts as a sought of starter motor like in a car just to give the engine its first kick to get momentum going) isnt working which means your motor will try and turn around you will hear it humming but wont actually turn around and will eventually just get extremly hot and trip the thermal overload switch, you should take the back off the unit and check the belt (really easy just look at it to see if it is around the drum not to tight but tight enough to grip) then have a look at the capacitor normally a damaged cap has noticeable visual signs check for any signs of bulges, burn marks or splits (IF YOU KNOW HOW TO CHECK ITS CAPACITANCE WITH A MULTIMETER BUT BE EXTREMELY CAREFUL AS CAPACITORS CAN HOLD THERE CHARGE REGARDLESS IF POWER IS OFF OR NOT AS THIS IS THERE WHOLE PURPOSE ALTHO MOST MODERN CAPS HAVE BLEED VALVES THAT WILL DISCHARGE ANY UNUSED ENERGY ONCE POWER IS DISCONNECTED BUT YOU CAN NEVER BE TOO SAFE WITH THAT AMOUNT OF VOLTS ALWAYS DISCHARGE BY SHORTING THE 2 TERMINALS WITH 1000V INSULATED PLIERS) I suggest if you dont know much about capacitors not to touch it as they can hold over 400 volts
Apr 15, 2011 | Samsung DV219AE Dryer
I need a 220 volt timer for Malber TD700 drier.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Sep 02, 2010 | Malber TD700 Electric Dryer
Malber TD700 sensor tumbles but no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 05, 2010 | Malber TD700 Electric Dryer
Tumble dryer drum only starts when i start it first by hand
starter capacitor went bad on motor... replace
Mar 12, 2009 | Dryers
Dryer Gets Hot..But doesnt Spin
I don't know what kind of dryer you have, top or front loading, but it top loading it most likely is the belt that goes from the motor & wraps around the drum.
Dec 21, 2007 | Malber TD700 Electric Dryer
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Malber TD700 Electric Dryer Logo
481 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Tim Whalen
Are you a Malber Dryer Expert? Answer questions, earn points and help others
