Question about Coffee Makers & Espresso Machines
Error code 2 when trying to descale teuco steam shower
2 Suggested Answers
  • 1587 Answers
SOURCE: After completing a descale the
The water spray head is clogged up with pieces of scale. You'll have to take it off and rinse it out. If necessary, use a pin to pick the scale out of the holes in the spray head.
Posted on Nov 27, 2010
I need help understanding how to descale delonghi expresso machine
hi Kathy.
see if this helps you out.
For machines without an automatic descaling cycle:
  1. Dissolve the descaling agent into a full reservoir.
  2. Pull the solution into your boiler by running about a cup of water out of your steam wand. ...
  3. Turn off the machine and let sit for 20 minutes. ...
  4. After 20 minutes, run about 1/2 of the reservoir out of the steam wand.
How to Descale Home Espresso Machine
or try this link.
how to descale delonghi espresso machine Google Search
Dec 12, 2017 | DeLonghi Coffee Makers & Espresso Machines
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Oct 19, 2014 | Gaggia Titanium Espresso Machine
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats http://www.bluestarcoffee.eu/ascaso--boiler-thermostats-x-2-193-p.asp
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
http://www.bluestarcoffee.eu/ascaso-gasket-kit-dream-arc-basic-114-p.asp
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Feb 01, 2010 | Miele DG155-1 Steam Oven Single
We have a Talea Touch Coffee Maker and when you try to brew the espresso only a little coffee comes out the coffee spout and the water that should come out with the coffee is comming out the steam spout....
First remove brew unit and clean the shower screen that is under the red gasket, then adjust the grind about 2 numbers coarser, then try making a coffee, if you have the same problem then the steam valve needs to be replaced.
Nov 09, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
How do I descale my Breville BKC600XL
Why not just fill the tank with vinegar & run it through as per the manufacturers instructions
Nov 07, 2009 | Breville BKC600XL Coffee Maker
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Aug 20, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
128 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
