Question about DeLonghi ECAM 23.450 S Espresso Machine & Coffee Maker
Can't not remove the infuser Delonghi ECAM23.450S
I just buy the machine 1 month ago via amazon and now I can't use it because there's warning in monitor "GENERAL ALARM" so I try to open the infuser to clean it out, but its difficult to open it, I already press the two red button but still stuck until my hand painfull , please explain to me how to open it?
ginko
  • 19396 Answers
SOURCE: tried to remove infuser, must
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
Posted on Aug 20, 2008
SOURCE: infuser will not come out, can anyone help?
the infuser is tilted and I cannot get it back to center
Posted on Dec 09, 2009
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
Dane1234
  • 25 Answers
SOURCE: eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
Posted on Jun 29, 2010
SOURCE: insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
Posted on Sep 07, 2010
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Delonghi Magnifica Makes creaking noise when preparing brew unit
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
May 19, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica always asks "Insert Infuser Assembly"
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi ECAM 23.450 S Espresso Machine & Coffee Maker Logo
376 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
