Question about Kyocera FS1120D Laser Printer
Install Fs 1120D in windows 98
Install printer on old Windows 98 computer
Windows 7/64 doesn't list my printer
The cd only has the drivers that were available when the printer shipped. You download the latest one here:
https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1100._.EN.html#WIN7
And yes, it does have drivers for both 32 and 64 bit Windows 7
Apr 01, 2017 | Kyocera Mita FS 1000+N Laser Printer
Good morning, I have a windows 98 os, mouse (m-rn67) stopped working. no luck using newer mice, doesn't recognize. can i update computer using usb w/driver for newer mouse?
Hi janettgordon,
I am not exactly sure what you mean by "can i update computer using usb w/driver for newer mouse", but if you want to know if you can update the USB component of Windows 98 I regret to say to you that it's not possible.
USB support on Windows 98 always been tricky and Microsoft never officially supported it before Windows 98 SE. I don't know what version you have, but either way USB support under Windows 98 never been great. You also need to keep in mind that Windows 98 is quite an old system and no recent hardware like mouse, keyboard, printers is supported on it anymore.
My advise would be to upgrade your current Windows installation to Windows XP or Windows 2000. A friend can probably lend you a copy and I'm 100% positive that it will solve your problem with newer mices. You will need to make sure your computer can handle Windows XP or 2000, but they can run under pretty old hardware so it should not be a problem.
Cheers!
Mar 01, 2011 | Logitech Cordless Mouse
Will not print correct as a network printer
1. Define your Star Micronics Printers device model TSP600
2. Define your operating system to install your Star Micronics Printers device
3. Search Printers driver category
4. Find Star Micronics Printers driver
5. Select Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
6. Download Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
7. Install Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
8. Restart or reboot your computer to finish your driver installation.
Download here:
http://www.opendrivers.com/driver/247183/star-micronics-tsp600-printer-network-setup-utility-ver.-2.0.1-windows-xp-2000-me-98-95-free-download.html
Aug 16, 2010 | Star Micronics TSP600 Thermal Printer
Have a new computer with windows 7 - the lexmark X5470 printer I have was hooked to my old computer with CD Windows 98 Op - how do I reprogram to new computer
There is no specific software required for the printer to work in Windows 7. When you plug it in Windows should find the driver in it's own driver data base and the printer should function. Below is a link to a Microsoft video explaining how to manually add the printer.
http://windows.microsoft.com/en-US/windows7/Install-a-printer
Alternately you can download and install the Vista drivers as recommend by Lexmark for Windows 7 use.
http://support.lexmark.com/index?segment=DOWNLOAD&userlocale=EN_US&locale=en&productCode=LEXMARK_X5470&page=recommendedDownloads#1
Jul 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
I can't get a drive for laser printer kyocera fs 720 in pc with windows 7.
http://kyoceramita.com.au/fs720.asp has xp driver for fs-720
attach fs-720; windows 7 will recognise but fail to install
click on 'unspecified device fs-720' in devices and printers
click to upgrade/install driver
use driver specified above (xp)
should install properly
cheers
Feb 14, 2010 | Kyocera FS-720 Laser Printer
How can i install a canon ip 1900 in windows 98?
Try going to the Canon website and download your software. ( http://software.canon-europe.com/products/0010647.asp )
Uninstall any software that you may already have install for the Canon by going to ' add & remove programs ', uninstall your canon printer by going to ' printers & faxes, disconnect your Canon printer from your computer.
Reboot your computer.
Install the Canon printer software that you downloaded.
Hook up your Canon printer to your computer.
The software should install automatically. If not, re-install the software you downloaded.
Mar 23, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Need driver CD for HP3740
Hi
The printer doesn't support windows 98. supported systems are:
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
» Microsoft Windows XP
» Microsoft Windows XP x64
» Microsoft Windows 2000
» Mac OS X
» Mac OS 9
» Linux
Drivers are available at this page below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=401496&lc=en&cc=us&dlc=en&submit.y=3&submit.x=8&lang=en&cc=us
Note that there are no drivers for 98 and it won't be simple to get the printer to work with the 98.. I would recommend upgrading to 2000 or windows xp. if your computer is from 1998 it might be better to buy a new computer.
Todays printers don't work with 10 year old computers anymore.
linux would work on the computer for sure, and so would the printer but using linux is quite complex, you would need to get someone to install it for you and make it look as much like windows as possible, its a whole new system..
Let me know if you need anything else.
Thanks,
Ekse
Feb 10, 2009 | HP DeskJet 3740 InkJet Printer
Windows 98 install
It could be a memory related problem. Try to test your memory module by installing it to a different system that is surely working. If that system restarts, then you must replace the memory module.
Nov 20, 2007 | Microsoft Windows 98 for PC
Kyocera FS1120D Laser Printer Logo
104 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
