Question about Xantech D5SHK4 DIGI5 4 X 4 4Source 4Zone Wall Mount Kit
D5SHK4 shows 1.0.7 - Xantech D5SHK4 DIGI5 4 X 4 4Source 4Zone Wall Mount Kit
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
One particular sales voucher date to change, but (tally 7.2) error shows "date below starting of books"
last financial year I have completed (1-1-2012 to 31-12-2012) Next fin.year I created (1-1-2013 to 31-12-2013) and keep current date (to day 13-1-2013) I start the payment voucher from 1-1-2013. But it showing date below starting of books 31-12-2013. In configuration (Skip date field in to NO.. But not possible to do entry. pls help. Email : pkumarlondon@gmail.com.
May 25, 2011 | Computers & Internet
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Dual sim china mobile show on screen invalid sim
I HAVE A CHINA SET SIGMATEL S90 DUAL SIM ONLY SIM 1 IS WORKING FOR SIM 2 SHOWS AS INVALID SIM FROM FEW DAYS PLEASE SOLVE THIS PROBLEM
BABU
9035040544
May 27, 2010 | Sharp Cell Phones
I taped 8 hours of programming in LP mode and want to burn it onto disc. Can I use the divide title mode to split the title into 3 segments so I can fit on 3 discs?
Yes, go into hdd list of recorded shows and select show
edit, chapter mark, find about 1/3 of show, select mark,
yes, back 1 menu under chapter mark is split or cut,
just select and you now have 2 files, 1/3 of show and 1 2/3 of show, just repeat, for 3 parts. and burn to dvd.
Jan 07, 2010 | Philips DVDR3576H DVD Recorder
How can i change the month/date format. it shows the day then the month example: nov 1 shows 1 11
you start by going to http://www.sourmath.org/ there, they have a video showing how to do it. lol im 2 lazy 2 do it hope this helps!
-Old Man #1
Nov 11, 2009 | Watches
VIP722 Shows about 1/2 of recorded show and quits
The short answer is that you have a corrupt hard drive and the receiver needs to be replaced. Thanks for using Fix Ya.
Apr 10, 2009 | DISH Network DVR-625 DTV Receiver /...
My ipod is 1 gb now it shows on pc 1 mb
you can try reformatting the ipod by going to my ipod in itunes when your ipod is connected.
Dec 11, 2007 | Apple iPod nano
Xantech D5SHK4 DIGI5 4 X 4 4Source 4Zone Wall Mount Kit Logo
37 people viewed this question
Top Xantech Home Security Experts
Lawrence Oravetz
Are you a Xantech Home Security Expert? Answer questions, earn points and help others
