Question about Sony WEGA KLV-23M1 23 in. HD-Ready LCD Television
Very very light brownish tint area of discoloration
There are 3 areas of very light screen discoloration. One area is closer to the top of the screen and another area is directly below it nearer to the bottom. The third area is between the 2 but offset to the right. These areas are only noticeable when a very light background is on the screen such as the light gray you would see in a black and white movie. These areas are always the same no matter what input source. So far it does not seem to be getting any worse. Thanks for any advice on what this might be caused by.
  • Anonymous Apr 20, 2009
    I have the same problem in the bottom right hand corner.
  • 11 Answers
SOURCE: screen discoloratiom area
It's definitely your VCR that is causing the problem. Move your VCR, if you don't get any results you need to send it to repair.
Posted on Jul 10, 2007
jerryg50
  • 1667 Answers
SOURCE: pulsing/strobing on black screens or dark backgrounds
It is very likely that there are electrolytic capacitors going high in ESR on the processor and driver boards, and also in the power supply areas. The tech should be able to see this by monitoring supply distributions with a scope.
Depending on the complexity of changing the caps on the boards (if it is actualy a cap problem), the best choice may be board replacements.
In almost all the cases where I had this type of fault, it was a number of capacitors that had to be replaced.
Jerry G.
Posted on Apr 14, 2008
  • 2318 Answers
SOURCE: Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Posted on Jul 01, 2008
SOURCE: yellow tint on screen, little bright spots on the dark blue.
http://repairs.sunnyoasis.com/sonylcdtv/ this is a link on what to do i had same problem picture is like brand new now good luck this takes about 3 to 4 hrs
Posted on Jan 04, 2009
  • 4 Answers
SOURCE: screen appears blue
It's the Light Engine (also called an Optical block) -very expensive.
Posted on Jan 08, 2009
Polaroid TLX-04011C 40" TV Flickering Screen
That problem with ur panel. you can do nothing about it ..
repairtv ca
Jan 15, 2014 | Televison & Video
Green tint in the color on my big screen tv
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 12, 2017 | Samsung Televison & Video
Diffenent tint to 4:3 area during full screen projection.
di you try to conv. it and if that don,t work you need to see a tv repear
shop
Dec 07, 2009 | Toshiba 50H82 50" Rear Projection...
55'' rear projection Phillips (dptv335) Red Tint in 4:3 area
Sounds like your fluid in the CRT's need replaced. I would recommend a servicer take care of that problem. The corrosion that ethylene glycol can do to components is vast if you spill it on any of the PC boards. ( You know it as Anti-freeze ). Play it safe---Make a Call.!
Jul 24, 2009 | Pioneer Televison & Video
I just replaced the convergence chips cuz I thought they were bad but I still have the screen with an arc at the bottom and the top of the screen...any other ideas???
There are usally 2 or 4 resistors that have to be changed out after replacing the amps.You can identify them by their discoloration.Should be brownish and burned.They are in the area of the amps.The value is 6.8 ohms.
Jan 19, 2009 | Philips 60PP9202 60" Rear Projection...
Jul 01, 2008 | Sony KV-32FV27 32" TV
Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Aug 16, 2007 | Hitachi 51F510 51" Rear Projection...
Screen discoloratiom area
Jul 10, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Dark (brown-yellow) area on the screen
Dalnel97,
Did you ever find a solution to your yellowish brown blob? I have the same problem with mine here at work.
Jun 12, 2007 | Panasonic PT L720U Multimedia Projector
Sony WEGA KLV-23M1 23 in. HD-Ready LCD Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
