I am having error E000014-0001 in canon ir 4570
To jeff heightchew
i try for your intructions, but that code appear again ....so, what the fixing ..?? i'm wait for your answer .... thanks
Posted on Nov 19, 2012
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
iwlsolve
  • 62 Answers
SOURCE: error e00061-0001
this error is sensor problem at drum's top sector.
i think it's name is IT sensor.
u can see at top of drum.
first : clean this sensor and re plug, if it is not fix this problem , u must be change this part.
Posted on Aug 18, 2009
john504
  • 31 Answers
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
Developing assembly connector is disconnected.
Did you have a drum or service do latly? Just sounds like a plug was left diconnected.
Posted on Jun 09, 2010
Cogz
  • 1326 Answers
SOURCE: I HAVE IR 4570 WITH PROBLEM E0000000-0001
E0000-001 means that the fixing unit is at the wrong temperture. Did you have a power problem recently? If so, you mat be able to rest the code. You have to get into service mode > press "*" then "2&8" at the same time then "*". the display will change > press "copier" then "funcation" then "clr" then "err" then pres the "OK" in the bottom right corner and then turn then main power off then back on. If the code can be cleared, you are back to work. If not you will have to have the Upper fixing unit or fuser unit replaced... Good Luck
Posted on Jul 04, 2010
  • 13 Answers
SOURCE: what does error code E000014-0001 on Canon iRC6800
check the sensers in fuser
Posted on Sep 19, 2010
E0002250001 canon 4570
Disconnect and than connect the flexible cable,if not okay,replace it
Jun 27, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon ImageRunner 4570 gives me an error code:E000001-0010
A E 000 code is a fuser ass'y problem. It will need to be rest in service mode...
Mar 04, 2008 | Canon imageRUNNER 4570 Copier
288 people viewed this question
jasbo
jasbo
