Question about Adobe Acrobat 6.0 Professional for PC
Adobe Acrobat 6.0
I have a problem downloading any pdf file utilizing Adobe Acrobat 6.0. I receive an error message reading "External Window Handler not found. This program had been running successfully until recently. But since I downloaded the program off the web, I cannot uninstall it easily.
  • 4 more comments
  • Anonymous Apr 23, 2008
  • Anonymous Jul 03, 2008
    my pdf certificate will not appear on screen
  • davohoh Aug 04, 2008
    Every time I try to open a file with acrobat 6 I get an illegal action flag.
    Seems to have just started doing this recently. David
  • asha_bhat1 Feb 18, 2009
    Sir,
    I have already loaded the Adobe Reader 6.0 from the very start in my PC which was helpinmg me to down load the files from the intyernet, But am sorry to mention here that few days back when I want to down load the file for reading/printing, is not down loading the file which results me in a great problem as I am not able to down load the tenders/offers from the net. Kindly do the needful and help me for resolving the same.
    Regards,
    PL Bhat
    asha_bhat1@yahoo.co.in, nachiketatechnology@yahoo.co.in
  • Anonymous Feb 20, 2009
    not open pdf file
  • Anonymous Feb 24, 2009
    please give me
A/a
Posted on Feb 11, 2009
    President:
  • 2,961 Answers
Normally if you click on help at top of menu, then detect and repair normally sorts it out
Posted on Oct 17, 2006
SOURCE:
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
How to Fix Adobe Acrobat Reader
Adobe Acrobat Reader needs to be updated. It sounds like your automatic update is turned off.
Mar 10, 2015 | Adobe Acrobat® 8.0 Standard Full Version...
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
I keep getting messages ..could not find acrobat External windows handler; . brand is e machines ..error messages,,
Hi Kate1958. I found this for you. Do one or more of the following solutions:
Solution 1: Remove all versions of Acrobat or Reader, and then reinstall one version.
If multiple versions of Acrobat or Reader are installed on the system, remove all versions and then install only one version. See the documentation included with Windows for information about removing programs.
Note: If you need to have multiple versions of an Acrobat product installed, remove all versions and then reinstall them starting with the earliest, installing the latest version last.
Solution 2: Start Acrobat or Reader, and then open the PDF file in the web browser.
If an error occurs when you try to start Acrobat or Reader, refer to Related Documents below, or search the Adobe Support Knowledgebase:
-- If you use Acrobat, go to www.adobe.com/support/products/acrobat.html .
-- If you use Reader, go to www.adobe.com/support/products/acrreader.html .
Solution 3: Make sure that the External Window Handler file (ewh32.api) is in the Plug-ins folder.
If this file is missing, reinstall Acrobat or Adobe Reader.
The default location of the Plug-ins folder is:
-- For Acrobat: Program FilesAdobeAcrobat [version]Acrobat
-- For Reader: Program FilesAdobeAcrobat [version]Reader
Solution 4: Disable Web Browser Integration.
Disable Web Browser Integration so that PDF files open directly in Acrobat or Reader instead of in the web browser.
To disable Web Browser Integration in Acrobat 6.0.x -7.0.x or Reader 6.0.x -7.0.x:
1. Open Acrobat or Reader.
2. Choose Edit > Preferences > Internet.
3. Deselect Display PDF in Browser.
4. Click OK.
To disable Web Browser Integration in Acrobat 5.x or Acrobat Reader 5.x:
1. Open Acrobat or Acrobat Reader.
2. Choose Edit > Preferences > General.
3. Click Options in the list in the Preferences dialog box.
4. Deselect Display PDF in Browser.
5. Click OK.
To disable Web Browser Integration in Acrobat 4.x or Acrobat Reader 4.x:
2. Choose File > Preferences > General.
3. Deselect Web Browser Integration in the General Preferences dialog box.
4. Click OK.
I hope this helps. Please dont forget to rate and provide positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Computers & Internet
When attempting to digitally sign a PDF doc. i get "error reading xref entry".
Alot of adobe downloads can be corrupted...try 'PDF 995' and see how you get on there ....you willl need to download all files ..so make sure you read the ditails
Oct 02, 2009 | Microsoft Office Xp Professional Full...
Is there any way to open an Acrobat 9 file with Adobe Reader 5?
Download the Adobe Reader 9 software. It's free from Adobe.
Mar 01, 2009 | Adobe Acrobat 6.0 for PC
Cannot use reader 8.0,cannot remove it or install 9.0
oddly enough, you may find that updating the version 8.0 you have to 8.x will then allow you to remove it (or it will work correctly) can you open the reader manually in the programs list? if so open it, then go to help and check for updates. apply the updates. If they work you should be in good shape.
Dec 24, 2008 | Dell Dimension 8400 PC Desktop
Adobe reader error message
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
Adobe Acrobat 6.0 Professional for PC Logo
227 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
