Question about Hardware & Accessories
Doorhandle forced when locked. now it will not open when unlocked
A heavy child locked my wife out of our house and when he tried to let her back in the house, he held onto the handle and put his entire weight on the handle. It is not a round knob type it, is the handle type. Now the door will not open when the handle is turned even though it is unlocked.
    Genius:
  • 1,605 Answers
Most likely the door frame is out of alignment due to the force of the weight.
you can try to open the door from the opposite side. push instead of pull.
if that doen't work, use a nail and hammer, remove the pins from the hinges pop open the door off the frame. (have someone braced the door before you push it.)
once you have it open check the alignment of the door frame, and realign it as necessary.
Posted on Dec 04, 2008
Child lock on, tried open Door Handle from inside, is the handle broken no longer open Door from inside even when child latch off 2003 Cadallac Deville
Hi. Try : unlock the car ( push open 3 times) open doors from outside ( make sure they unlocked) switch child lock to lock position and back to open. Pull again on the handle after you switch before you close the door. Let me know if it helped.
Apr 27, 2017 | Cars & Trucks
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
How to open back doors
You have to remove the door panel with the door closed, then switch the child lock to "unlock"
Oct 06, 2015 | 1997 Cadillac DeVille
Why won't rear passenger door unlock with auto lock switch?
latch may be damaged /gummed up --or lock rod/retaining clip damaged or disconnected you will need to remove the door panel to inspect the lock unit
Aug 09, 2015 | Lexus RX 300 Cars & Trucks
Unlock child safety lock
try unlocking child safety switch in door jamb
Sep 07, 2013 | Nissan Cars & Trucks
Back door will not unlock
i got peugeot 106 ...! when i waz washing my car by mistake i lock child safety lock....! and i can not open it agein how ever i manage to un lock child key but the door still lock plz help thanks,,,,,( i tryed evre thing)
Mar 21, 2012 | Cars & Trucks
My back doors wont open, the child safety locks wont unlock my back doors
Your post is somewhat confusing, BUT with child locks engaged, you can only open the door from the outside, when unlocked.
Jul 10, 2011 | 1999 Ford Explorer
Honda Accord Outside handle broken and Child lock is on.
Remove the panel and disable the child lock or some cars have an option to just bypass the child lock either or
Jun 07, 2009 | 1999 Honda Accord
Hisense tv on "lock"
If you have the original remote with the "CCL" Child Lock it unlocks it. If you are like me and lost the remote I unlocked mine by 1. Turn on TV 2. Hold down the menu button and unplu it. 3. Continue to hold the menu button down while you plug it back in. Mine unlocked, good luck.
Paula
Sep 06, 2008 | Hisense Televison & Video
Door lock accent 2000 rear door lock jammed
door handle on the out side has never worked. And my wife moved the child saftey lock to the locked position and closed the door, now we can't open it. How can I move the child saftey lock back to the unlocked position when the door won't open?
Jul 02, 2008 | 2000 Hyundai Accent
Hardware & Accessories Logo
211 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
