Question about Philips Magnavox MPD845
Battery won't charge
When I plug the unit into the charger, the battery will not charge. no lights on or anything. only works when plugged into the wall and on. Please help. Bought this for trips, and now it's just a 10 pound paperweight.
    New Friend:
No. Battery is not the problem, appeared to some charging circuit board issues. Got two Sony DVD player one (DVP-FX820) and the other (DVP-FX811) exclusively for Sam's Club. I keep switching batteries to charge on the FX811 (good one), haven't found a solution yet.
Posted on Aug 28, 2013
  • 291 Answers
A couple of things could be the problem.
A special circuit detects when the battery needs charging, it is suppose to charge the battery, that could be bad.Sometimes, a special circuit charges the battery WHILE playing the movie.
The battery could be 'dead' not charging and the same circuit tells it to bypass charging and go directly to turning on the set.
If you got it from a person that has the knowledge, they could have bypass the charging circuit and wired it to just turn on.
You did not say that you got it new and in 'charging ' working order.
Usually the batteries have to be replaced after a number of charging. [you did not say how long you had the machine.
If you know how to do it, replace the batteries. If not get someone to do the job.The cost of batteries and labor.
Posted on Oct 25, 2008
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My dads scooter won't charge. No light comes on indicating it is even charging. Is there any way to check charger operation?
Good day,try visiting where the scooter was made & download a user guide for the scooter model you have.It could be something simple,like a fuse blown in the charger.Never rely on a new fuse will work,better to take the same rating fuse out of something that you know works with the fuse you need.I hope I have helped,Colin
Mar 04, 2013 | Electric Mobility 4 Wheel Power Electric...
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer Computers & Internet
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
Hard reset and charging problems
do the hard reset again .. hold the power button down while operating the reset in the back .. keep the power button down for a few seconds .. that should bring up a display "delete all" .. you can choose to do so .. that will be a hard reset .. now if the battery is dead and the charger is not working then nothing will work for you .. you might have a bad charger .. often the end that plugs into the unit develops a broken wire inside the cable ..
the m515 wont charge from the sync cable (shame) it needs the external power adapter .. make sure the connections on the charger and palm are clean .. the power adapter is 5 volts and i think about 1 amp .. )(center pos) if you want to try another adapter .. the tip is rather standard ... also you can get a universal power adapter from radio shack that will work on just about anything .. you just plug in a suitable tip .. the tip for your palm is an "A19" .. the power adapter is "IGO" wall adapter 23-1401 model PSM08VADJ ... that seems to work nicely and it plugs directly in to the palm .. so you can work with it plugged in .. when the charger is working there should be a lightning bolt thru the battery symbol .. it sounds like you already know that .. if the battery has gone open then it may not indicate a charge .. but the unit should still work while on the charger if that is actually working ....
Apr 13, 2009 | Palm m515 Handheld
Philips Magnavox MPD845 Logo
506 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
