Question about Sony Playstation 3 (PS3) Console
2 discs stuck in PS3.....
The helpful 6 year old loaded 2 discs into our PS3, of which one might be upside down. The sticky tabs on the bottom of the case were removed to reveal molded case, so how exactly do I tear this thing open and/or fish the discs out?
  • MEjazz Dec 17, 2008
    My 18 month old did the same. I tried to get them out using a 3rd disc and now it resides in my PS3 as well :) HOW TO GET 3 DISCS OUT OF MY PS3?
    Problem Solver:
  • 7 Answers
I can fix this for you!
go to this link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300318746769
when you get your ps3 back it will work perfect and the discs will be out!!!
Posted on May 30, 2009
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    My disc is stuck in the system
    There is no need to open up the console! Get someone to hold the PS3 upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from eachother so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
    Jan 31, 2010 | Sony Playstation 3 (PS3) Console
    No power
    I can help you get the disc out as for the repair I can;t help as I'm in the UK!
    There is no need to open up the console! Make sure the power is off! Get someone to hold the PS3 upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from eachother so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
    Jan 11, 2010 | Sony Playstation 3 (PS3) Console
    My son has put two discs in ps3 and cant get either out now
    I researched this problem since my twin 2 1/2 year old sons decided that my PS3 was hungry and needed a steady diet of 3 discs all at once. On a similar discussion board, someone discussed using butter knives to pinch the discs (one on top and one on bottom) and pull them out. This worked to perfection! Just be sure to pull the power cable from the back of your PS3 prior to sticking any objects (i.e. metal knives) into the front of it.
    Nov 28, 2009 | Sony Playstation 3 (PS3) Console
    My child stuck something in ps3 and now my game is stuck as well
    There is no need to open up the console. Make sure the power is off! Get someone to hold the PS32_bing.gif upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from each other so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
    Jun 06, 2009 | Sony Playstation 3 (PS3) Console
    Something stuck in disc drive of ps3
    There is no need to open up the console! Make sure the power is off! Get someone to hold the PS32_bing.gif upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from eachother so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
    Jan 10, 2009 | Sony Playstation 3 (PS3) Console
    Was playing game went to turn off to change and disc stuck wont come out
    I can help with getting the disc out.
    Dec 31, 2008 | Sony Playstation 3 (PS3) Console
    System wont load or eject any discs...
    Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
    Carefull remove the guide mechanism (the front part -1 screw).
    The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
    mount back the guide mechanism, and the top part.
    Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
    That will reset all the gears and stuff.
    Worked for me when I experienced that issue.
    Sep 05, 2008 | Sony Playstation 3 (PS3) Console
    Playstation 3
    Hold in ps button, switch off system, restart then go to options in menu and select eject disk.
    Dec 30, 2007 | Sony Playstation 3 (PS3) Console
    PSP Game Stuck in PS3
    1. Unplug PS3
    2. Stand up so as you are looking down into the disc opening.
    3. Fold out the felt that protects the drive.
    4. Look for what resembles a disc. (You should see it)
    5. Take to butter knives from your kitchen and with both hands use it like tongs to go into the drive and pinch the disc.
    6. Pull out the disc and your DONE.
    Worked for me a couple of times.
    GOOD LUCK
    Dec 07, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    168 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
