Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Bizhub c351 login error when scanning - Konica Minolta bizhub C351 All-In-One Laser Printer
Kevin Hayes
  • 167 Answers
SOURCE: weird scan problem with Konica Minolta Bizhub C351
It sounds like you have setup a fax forward box.
You need to set up a one touch, scan to SMB.
this can be easily done via your web browser by typing in the IP address of the MFP and set it from there.
You need the IP address of the laptop and is best to put the shared folder in the main drive (C).
Then for the file path you just need to enter the name of the shared folder EXACTLY as it is on the lap top.
You also MUST enter the ID a password to give it access.
Posted on Oct 24, 2008
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
Posted on Dec 22, 2008
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
  • 51 Answers
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Posted on Aug 30, 2009
  • 44 Answers
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
Posted on Nov 29, 2009
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
I am receiving an error when scanning, the error has no number and says to check the log. When I go online and check the log all it says is that the scan job failed.
From the panel, check the job log.
select the job that failed and then the "DETAILS" button will become active and present a more detailed report.
Jan 06, 2010 | Konica Minolta bizhub C351 All-In-One...
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
Adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
Utility/Counter button
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
May 01, 2009 | Konica Minolta bizhub C351 All-In-One...
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
How to set scan for a new person on bizhub c351
After pressing "scan," press "Direct Input," then "Scan to E-mail." That will come up with a digital keyboard with which you can enter the e-mail. You'll have to type out the whole address, as on my printer (even though I have the manual) I can't seem to find out how to save it so you don't have to type it in every time...
However, after inputting the e-mail address, press "Start" and it should scan to the e-mail.
Nov 19, 2008 | Konica Minolta bizhub C351 All-In-One...
Weird scan problem with Konica Minolta Bizhub C351
Oct 14, 2008 | Konica Minolta bizhub C351 All-In-One...
Error 2652
C2652 Magenta Imaging Unit EEPROM access erro. you need to:
1. check if EErpom of Magenta Unit is not dirty. if it is, clean it.
Else, replace the Unit image.
Aug 08, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
