Question about Whirlpool Dryers
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
My whirlpool duet dryer is tripping the breaker after running for a few minutes. It doesn't trip the breaker when on the air-only cycle. I just moved, so I am not sure whether to call an appliance repairman or an electrician. We dried a couple of loads the first day we moved in without any problem. Then, I rearranged the washer and dryer and forgot to put the washer drain hose down the drain, so some water got behind the washer and dryer. I'm not sure if this caused the problem or if it's something else.
  • Whirlpool Master
  • 2,320 Answers
It caused the problem. Appliance repair person
Posted on May 14, 2017
  • 262 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
MAKE SURE YOUR VENT ISNT CLOGGED AND YOU HAVE 220 VOLTS AT THE DRYER IF ALL THIS CHECKS OUT GO TO ELEMENT WHICH IS BEHIND THE LOWER PANEL IN THE FRONT.REMOVE THE PANEL WITH THREE SCREWS ON THE BOTTOM AND TAP DOWN AND OUT AT THE SAME TIME. USE A VOLT OHM METER AND CHECK OHMS ACROSS THE TERMINALS OF THE HEATER IT SHOULD HAVE A OHM READING IF NOT CHANGE HEATER AND OPERATING THERMOSTAT GOOD LUCK
Posted on Dec 16, 2007
  • 1314 Answers
SOURCE: Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Posted on Jan 10, 2008
SOURCE: Whirlpool Duet Sport Dryer PF code
dmarshall05 again:
Two technicians have been out (new guy & experienced guy). First tech didn't take lower panel off, but 2nd tech did and found that drying vent tube (4" tubing) had disconnected. I replaced the rigid vent that came with it to vent to the left side instead of the back. That was 6/3 and today is 6/6 and it hasn't happened since. It was happening every load where it would run 3 minutes and shut off, then cool off for 5 minutes, run for 3 ....
Check you vent tube. I'll post again if this turns out not to be the solution.
Posted on Jun 06, 2008
WRMtech
  • 70 Answers
SOURCE: no power to maytag duet
most maytag "performa" dryers with no power h appen froma blown thermal fuse. It is located under the top and beside the heating element. you can take an ohm meter to both terminals.If you do not get a reading, the part is bad. It comes as a kit with a new safety tstat
Posted on Feb 19, 2009
  • 686 Answers
SOURCE: How do I reset breakers on whirlpool duet dryer?
What size breaker is the dryer on it's should be at least a bouble 30 Amp breaker
Posted on Mar 06, 2009
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
Whirlpool dryer, tripping breaker. Dryer spins but no heat.
If it's tripping your home breaker. You most likely have a bad element. It could also be a loose wire but I would not thing so. You can remove the element and check it. You will most likely find the element is broken and touches the plate when it starts running, shorting the dryer and tripping the breaker. Good luck!
Nov 23, 2009 | Whirlpool GEW9250 Electric Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Jan 10, 2008 | Dryers
Duet Dryer will not start, Press control on, Start, then it beeps
try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
Dec 08, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Dryers Logo
257 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
