Question about SanDisk Sansa Clip MP3 Player
Sansa clip won't recharge on my older pc
I was able to recharge the clip (4G) on my daugters pc. but I'm unable to recharge on my older pc. My PC's UBS port is not highspeed. Should it be able to recharge 1.5 USB. Thanks in advance for your help. Anna
  • 8,596 Answers
USB 2.0 only.
Posted on Jan 01, 2009
How to fix a sandisk fat is corrupted please recover fat
You could try the following:
Start with the Clip turned OFF. Slide the power switch down to the HOLD position. Press and HOLD the center button depressed until it is recognized by the PC- give it a few seconds.
The Clip's display will state "connected" with the device now in MSC mode.
You can now repair the File Allocation Table (FAT) using Windows' chkdsk utility.
Open My Computer and find the Clip a listed under "devices with removable storage" as a flash drive. Let's say it displays as E: SANSA CLIP for example. Our assigned drive letter is E:
From the Run box under Start, enter cmd and press Enter. You will get a DOS window.
Enter chkdsk E: /f and press Enter. The /f toggle tells the utility to fix the errors.
After clicking on the Safely Remove icon in the taskbar, or right clicking on the Clip and selecting Eject, unplug the Clip.
Try powering it up again, and see if all is well.
I found this at: http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/FAT-is-corrupted-On-Clip-4G/td-p/250798
Dec 31, 2014 | SanDisk Sansa Clip MP3 Player
Virgin Mobile Overdrive 3G/4G Pro won used on eBay and cannot activate.
They are correct. You will need to replace the SIM card.
May 27, 2013 | Computers & Internet
My sansa just stoped. it will not power on, I have had it a little over a year, really have not used it very much but I have a bunch of music I would really want to save if possible if the player is no...
mainly caused by flat battery, try to recharge the battery, or plug it into your PC and switch it on. If you are lucky, you can get your musics back by copying to your PC
Apr 11, 2010 | SanDisk Sansa Clip MP3 Player
My computer is not recognizing the sansa clip, I am unable to recharge the device anymore, and it does not appear in my drivers. I have retried loading the disk and nothing happens...please help!
Have you tried going to settings, then system settings and changing the usb mode? I have had some computers not recognize my device and this has helped. MSC should be he default mode and your device should show as a drive. The MTP is for DRM management. I have also had a clip that did this and my usb cable was bad.
Jan 04, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip mp3 won't get connected into the pc...
it must be something with the usb cord that connectes it with the computer.so go out and get a new one and se what happens.
glad to help.
Dec 23, 2009 | SanDisk Sansa Clip MP3 Player
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
Cannot install SanDisk Sansa Clip 4g on my new
there is no need to install it just go to control panel and click on portable media devices
Mar 22, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip mp3 player 2GB shows as UNKNOWN DEVICE when i connect
Sandisk website will have it, and will have the vista compatible software:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
here is the link for the sansa updater.
Ok...here is something you might want to do....I know you already formatted your device a zillion times already but please do it one more time using the Format option under Settings menu in your device....then restart your computer....then plug in your computer again after restarting to see if it recognizes now.....if not...here is one thing you could do....go to this link
http://www.nirsoft.net/utils/usb_devices_view.html
download the USBDeView software and see if the registry has the player in there....select it and delete it and then plug in your PC again to see if it will re-register the device and works...hope this will help.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
