Question about Bosch KGU31164GB Bottom Freezer Refrigerator
My refrigerator Bosch KGU-34610 has a constant red light on. What could be the issue and how to solve it? and where could i get its manual..its like Bosch doesnt even recognise it
3 Suggested Answers
SOURCE: where can i get a replacement control module for
repairclinic.com
Posted on Apr 04, 2009
woodchuck789
  • 4070 Answers
SOURCE: bosch fridge freezer not freezing
Make sure the fans are running. One is the condenser fan outside the unit near the compressor at the back. The other fan is the evaporator fan inside the freezer. You may need to hold the door switch in to make it run. If the evaporator coils behind the back wall in the freezer are iced up you may have a defrost problem.
Posted on Sep 14, 2010
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
Water leaking from bosch freezer kgu 34665 gb
Very little info to go on, but it would have to be water valve, lines going to and from valve, ice maker, or defrost drain leaking from being stopped up.
Dec 26, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
My refrigerator has been freezing all my food, so I cleaned everything out and restarted the unit. The freezer lights are showing the red triangle light up after starting it up. I don't know what's wrong...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 14, 2011 | Bosch Classixx KGV28323 Bottom Freezer...
I need a manual for Fridge Freezer BOSCH KGU 34645 GB
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 24, 2010 | Microwave Ovens
Bosch stand alone freezer Intelligent 32 - how to defrost
Hi
I have the same refrigerator and found the manual;
"The refrigerator compartment was programmed to defrost automatically meaning you do not have to constantly clean and dry it. Copy from the manual"
Also have a look in the back for the drain outlet - very small. If that is clogged up it also cause water on the inside.
Feb 28, 2009 | Bosch KSR34464 Refrigerator
Frost free fridge freezer has build up of ice at bottom of freezer section. i have defrosted many times but problem remains. model KGU 34620/07 Can you help
yes,
you have a defrost problem, three things..
one, defrost heater could be bad,
two, bi-metal could be bad,
and three, the timer could be bad.
any of these three items getting bad would result to one symptom.
ice buid up at the bottom of freezer section.
tnx 4 using fixya,
drcool
Aug 26, 2008 | Bosch Refrigerators
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch KGU31164GB Bottom Freezer Refrigerator Logo
85 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
