Question about Dyson Ball DC24 Bagless Upright Vacuum
Nothing going into canister
Cleaned filters, still have suction, even with the wand. However nothing is going into canister. I can only imagine it is clogged and compiling in other areas of the vacuum. Any advice? I don't seem to have the screw driver to take it apart? Is it a T10 screwdriver?
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC24. If you're concerned that your machine may be blocked, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
Please note - we'd advise against dismantling your machine any further than shown in the guide, as this may permanently reduce performance, and can void our 5-year guarantee.
Following the guide should resolve the issue, but if you'd like any further help or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Posted on Feb 16, 2012
SOURCE: Dyson vacuum no suction
Clean the mini cyclones in the Canister or clean the filter.
Posted on Oct 07, 2007
SOURCE: Dyson Animal clogged
Here is the best way to clean your dyson that I have found!
http://www.crazysquirrel.com/diy/dyson/cylinder-clean-page-1.jspx
Posted on Mar 02, 2008
pippall
  • 1486 Answers
SOURCE: Blockage in pipe of my dyson slim dc18
There sould be a rubber flap under the pipe.Pull it down to remove dust and **** that gets stuck.
Posted on Dec 27, 2009
Testimonial: "He was very helpful in his suggestions and after the first suggestion didn't work out he provided another. Thanks for the help."
  • 20 Answers
SOURCE: no suction
Sucked up a sock?? No seriously.. it may be as simple as that or that an on board filter is clogged. Check your manual for all filters and Hepa/screens and others. Also, is the unit making any odd noises since the non -suction scenario? Whining or screeching sounds, where is the motor impeller/vac bearing or similar is damaged or a hose is kinked within hte unit itself.. <not normally unless the unit has been taken apart and placed back together and crushed the main return vac hose. .
Posted on Apr 30, 2010
SOURCE: hi my dyson dc18 has great suction from wand but
want wont ****, or it wont turn off...here is what we did....
We used a bungee cord, hooked it up to the bottom red pedal and attached the other end of the bungee cord to the handle on the top of the vac filter so the that the red pedal would be forced to stay in the upright position so we could use the wand. the plastic piece came off and nobody at dyson seems to know how to fix it...
then, one day our wand suction would not turn off and no suction would come from the beater, well there is a little ball inside the vacuum behind the base of the hose, take off the hose, use your finger (it wont bite you) and rotate that white ball so that you can't see a hole. it should be solid, this will turn off the suction from the wand hose back toward the beater bar.
better than nothing.
Posted on Jul 14, 2011
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
My Dyson animal seems to have an electrical issue that I am unable to pinpoint. Neither the wand nor the floor vac have any suction AT ALL. In fact the vac makes absolutely no sound and you wouldn't even...
there is a filter inside the canister, and by your description it sounds like it needs to be cleaned. if you remove the filter and blow it out using a air compressor or using a slightly ridged brush and tapping the filter out this should solve your suction issue.
c...
Jan 02, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
Hi its Darran at Dyson.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Dyson Customer Service
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Has my Dyson lost suction??
just wash the filter on the top of the cyclone every 6 months.
Nov 14, 2008 | Dyson DC14 All floors Bagless Upright...
Red light for HIPPA filter won't go off
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Oct 25, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Dyson Ball DC24 Bagless Upright Vacuum Logo
54 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
