Question about Panasonic SC-HT740 System
My panasonic sa-ht740 keep showing me INIT when i turn it on
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
  • 10 Answers
SOURCE: panasonic model SA-HT740
Most F61 code failures are caused by a defective output ic.If all speakers are disconnected and F61 still comes up the IC is 100% bad.Needs to be serviced.Not an issue that can be fixed by homeowner.
Posted on Apr 05, 2008
SOURCE: Panasonic SA-HT740
I get this error usually once during a movie. Sometimes it is 10 minutes into it, sometimes it is an hour, and the only thing I have ever been able to do to get it to work, is to unplug the black power cord from the unit, for 20 seconds, and then reconnect it, and it usually works for the remainder of the movie. Would like to see a better fix, however!!
Posted on Oct 09, 2008
  • 336 Answers
SOURCE: PROBLEM F61 ON MY EQUIPMENT AND SHUT DOWN
You possibly took out the output ic by crossing speaker wires or touch one to the case when the other was in the terminal. (turn off and unplug when moving speaker wires)
Before taking it in remove all wires unplug power cord wait 30 seconds and plug just the power cord and turn on. If it still goes to f61 it's going to most likely need the output ic replaced.
$70-90 labor and about $100 for the part.
Posted on Nov 11, 2009
  • 1751 Answers
SOURCE: I have a panasonic home theater, model SA-HT740
check cablesof speackers comeware are cut
Posted on Dec 05, 2010
Panasonic f61 output
If what you identify as the output IC has failed, one or more speakers would be affected.
Nov 23, 2013 | Panasonic sa-ht930 Home Theater Audio...
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jan 13, 2011 | Panasonic SC-HT730 System
Want to use Panasonic SA-HT740 for TV sound
Get the TV audio from the Dish box directly to the receiver.
Feb 16, 2010 | Audio Players & Recorders
Reciver shuts off
Check your speaker and sub connections. When they are not imputed correctly the system will shut off.
Jan 10, 2009 | Panasonic sa-ht930 Home Theater Audio...
SA-HT740 Broken gear
You probably can get the parts from Tritronics, but as far as I know, there aren't hard-copy manuals normally made for any of the newer products. The only paper available nowadays are the users manuals... The service manuals are on-line at Panasonic and available only to authorized repair centers. Sorry.
I'm curious - how in the heck did a gear break in the thing??? There's nothing strong enough in the drive system to do that (either the motors would sieze or belts slip).
Bugman Mark
Nov 01, 2008 | Panasonic SC-HT740 System
"Panasonic SA-HT640" Code F61
Check to make sure Fan is turning at full speed
if not, replace fan
Feb 28, 2008 | Panasonic SC-HT740 System
Sa-ht740 power problem
I have same problems please If you know anything help me
my email adress
rifatsahin@hotmail.com
thanks
Nov 08, 2007 | Panasonic SC-HT740 System
Panasonic SC-HT740 System Logo
97 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
