Question about Dell 810 All-In-One InkJet Printer
Paper problems when i'm about to print the paper will not load into the machine, it goes down about half inch then paper jams comes up, i've tried reloading the paper several times but the problem continues i'd be gratefull of any help
I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
Posted on Aug 15, 2007
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
I have a Lexmark E240n printer. It keeps jamming at the same spot each time I try to print. Checked and tested the entry and exit switches. Checked good. All gears are turning smoothly. The paper jams...
does the exit switch stick up in the back of the fuser into the paper path? I've had to replace lots of the exit sensor flags because the top half was broken off while clearing a paper jam.
Apr 07, 2011 | Lexmark E240 Laser Printer
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Paper always on right when loading to be printed
Canon Printers are notorious for paper jams. Don't throw it out the window just yet, there are several solutions. Visibly check that there is nothing obstructing your printer (use a flashlight). A kitty may have hacked up a hairball (just kidding). Try a can of compressed air to blow out any foreign objects as well as turning your machine gently upside down to be absolutely positive nothing is obstructing the roller assembly. Next, open your Word Pad and type anything (like how much you are enjoying your Canon Printer Jamming and how you will recommend Canon Printers to all your friends), Use an A4 paper size 'POSTER PAPER' (the same size that you normally use (8 and one half inch by 11 inches) as this is thicker than what you would use. From your Word Pad, click PRINT, you will need to run the paper through several times and this will clean out any built up residue. If you do not have 'POSTER PAPER' a 'MAGAZINE COVER' will suffice (just be certain that it is the same size). After you have run your 'POSTER PAPER' through, load your regular printing paper normally and this should resolve your 'FANTASTIC CANON PRINTER'.
Oct 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Dell 810 All-In-One InkJet Printer Logo
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
