Question about Kettler Sport & Outdoor - Others
Kettler traveller 7885-000 dismantling
How to dismantle, with ref to electric cables?
SOURCE: How to dismantle SonyEricson v630i ?
LOL my friend also broke an egg on his phone. His buttons are sticking too.. just thought that was funny
Posted on Feb 10, 2008
  • 12 Answers
SOURCE: How can I dismantling printer Canon iP4300?
I just opened mine tonight after finally finding a picture of where the front tabs are!
On the back you will see slots with arrows, take a flathead and push it in the slot and push downward on the screwdriver.
Then pull the paper tray out and look here for the tabs on the front.
http://docs.google.com/Doc?id=df5t4sv5_7gnzwbtgn
I wouldn't recommend dismantling farther than this as this is pretty delicate stuff.
But you can clean your waste pads out where the head parks and make sure they are firmly in position. You can also do a general cleaning I suppose.
Big thanks to RossfroMoz for posting a link to these pics which really really helped.
Posted on Jan 21, 2009
shannongreer
  • 75 Answers
SOURCE: Kettler outdoor Table tennis table
http://www.kettlerusa.com/page12.html
Posted on May 18, 2009
  • 389 Answers
SOURCE: how can the sebo k3 be dismantled to fit a new
I wrote this guide originally for dismantling the Sebo K1, but I believe that with respect to the cable-rewind, the K3 is pretty much identical. So here goes:
1. remove the hose
2. remove the hose-retaining ring
3. remove the flap that covers the green filter.
4. remove the screw beneath that flap nearest to the handle (there's a deeply recessed screw on the other side, but you can ignore that)
5. remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver)
6. this is where it begins to get interesting. The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The first challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else. (The second challenge is getting it back neatly!)
7. remove the ends of the foam strip far enough to reveal two plastic clips that hold top and bottom of the body together
8. prise those clips off with a screwdriver.
9. it should now be possible to lift the top cover off. It can be a bit fiddly getting it off over the neck where the hose plugs in, but it does come off.
10. the cable rewind spool is now revealed in all its glory.
11. if you've found my advice helpful so far, here's a final piece... don't try to fit a new cable to the old spool - fit a complete new spool.
12. good luck!
I value feedback, so please remember to rate this response.
Posted on Jan 20, 2010
  • 389 Answers
SOURCE: Power Cable wires exposed where it enters handle
Part of your question has been cut off by the FixYa system, but I guess you say the wires are exposed where the flex enters the handle. To dismantle the handle, first remove the handle from the machine and, of course, be sure the flex is not plugged in to the mains power.
Look on the back of the handle - you will see a small screw. Undo that screw and remove it, then you will be able to pull the plastic part of the handle out from the metal part. NOTE: it does not come very far out - just far enough so you can separate the two halves of the plastic part. When you've done that, it's only a matter of removing the damaged part of the flex (noting how the wires are routed inside the handle), stripping the remaining flex to match the bit you've removed, and wiring it in. Fit the two plastic halves together again (one hooks into the other at the top), push them down into the metal part and refit the screw. Job done!
If you need more help, just post a reply here and I'll get back to you soon. Good luck!
Posted on Apr 05, 2010
Testimonial: "THANK YOU GOOD SIMPLE INSTRUCTIONS"
How do you dismantle control panel
The #1 rule for dismantling any control panel is to remove all sources of energy feed it first. That means if it is an electrical or electronic powered control panel, shut off, remove the fuse, or at least unplug the AC or DC electrical supply coming in. Secondly, do not assume the electricity inside the control panel is dead.
There may be a backup battery or even a capacitor that may still be holding reserve power. Keep a bright LED flashlight and magnifying glass on hand to carefully examine the control components for signs of arcing, as well as checking for power sources, and likely problems such as contamination or over-heating. Photograph and label every wire, plug and piece of hardware removed
Take notes of every sequence in dismantling so that you can properly reassemble later.
Mar 26, 2017 | Computers & Internet
I need a manual for kettler traveler
Touring Bikes Buy Commuter Bicycles Touring Bicycles More KETTLER USA Kettler USA online shopping for tricycles pedal tractors ellipticals... , Kettler USA online shopping for tricycles pedal tractors ellipticals... ,,If you are unable to find your product manual please contact KETTLER Parts:
Phone: 866.804.0440 Monday thru Friday 9:00 a.m. to 4:30 p.m. EST Fax: 757.563.9273 email: parts@kettlerusa.com
Mar 09, 2015 | Kettler Sport & Outdoor - Others
Wont restart
high pressure cut out switch faulty. dismantle unit dismantle and clean or adjust r replce micro switch ( on pump head )
Apr 19, 2014 | Task Force 2000 PSI Electric Pressure...
Was goin to buy a second hand kettler traveller but couldn't disconnect the electrics to seperate the treadmill to transport it any ideas
Dear Sir:
I recomend that you read your instruction manual carefully for warning, tips from the factory . If you do not have, please go the next web pages:
www.fitness.manualsonline. com or www.iconservices. com for free download.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 11, 2012 | Kettler Exercise & Fitness
A very old, extremely heavy dehumidifier sat in my mother's basement for decades. I decided to dispose of it, but I was unaware of the freon inside it. In order to extricate the dehumidifier I had no...
Yep the ref is all gone, The EPA says that the oil is hazardous, actually its just mineral oil the at one time had ref. R-22 in with it.
Jul 03, 2011 | Dehumidifiers
Instructions for dismantling for transportation
The Shoprider Soverign is not really meant to be dismantle for travel. The best you can do is to remove the seat and fold down the handlebars. Also depending on the year it was manufactured there is a pin towards the back of the scooter that connects the front chassis and rear chassis. You must first remove the batteries to gain access to the pin. If you are elderly you might need help. It is heavy.
Apr 09, 2009 | Electric Mobility Shoprider Electric Power...
Cleaning underside glas plate
Hi, I had to dismantle my HPG55 to clean the glass and found the instructions at the HP website. The link to the site is below. The instructions are very clear, and there are also photos to help you along the way. I hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=de&dlc=de&cc=de&docname=c00498704#N216
Sincerely,
Tosty
Feb 23, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Ignition replacement
1)First dismantle the batteryleads to avoid electric hazard.
2)Dismantle the steering wheel by taking the centre cover of with a screwdriver carefully,and then take the wires of the centre cover to the horn, loosen the nut 24mm in the middle but dont at first take it off, then wobble,and pull the steering wheel towards your self till it loosens, then dismantle the nut and take the steering wheel off.
3)Unsrew the 2 srews in the undercover and take the upper and undercover off.
4)dismantle the 2 or 3 screws (depending on model) pointing towards you, holding the wiper and blink contacts, dismantle the electric cable connections from the contacts and then remove the contacts from the casing.
5) remove the bolt in the housing (aluminium) holding the ignitionswitch, located from down without a head, needs a hammer and a chisel, can be hard to loosen.
6) turn the key clockwise so it pulls back the slot from the steering axel.
7) remove the electrical cables from the ignition switch.
8) pull the aluminium housing toward yourself sliding it upwards
9) exchange the lock,casing and electrical bottom piece all together and insert a new bolt in the aluminium housing
10) reverse to install
Jul 20, 2008 | 1991 Volkswagen Cabriolet
Sport & Outdoor - Others Logo
160 people viewed this question
Top Kettler Sport & Outdoor - Others Experts
Are you a Kettler Sport and Outdoor - Other Expert? Answer questions, earn points and help others
