Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System
Water accumulating on shelves in kenmore 72102100, turned off ice maker so its not that, and its not the water dispenser leaking, put pans in frig to see where water is dripping and its in the back by the vents, what causes this please?
  • 6 Answers
SOURCE: water dispenser dripping
HVACRH20, are you any good with GE water dispensers dripping? Let me know, I have a lot of info to provide and maybe you can help answer my problem?
Posted on Apr 02, 2008
ndguy2481
  • 251 Answers
SOURCE: Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Posted on Dec 04, 2008
rhinoking1
  • 85 Answers
SOURCE: water dripping from under feezer, have ice maker,
Check to see if your refer has a climate controll ie: humidity setting, some models of refers swet when the humidity is high, if it doesn't have this setting turn your freezer setting down alittle. GL hope this helps.
Posted on Jun 19, 2009
beamerguy740
  • 65 Answers
SOURCE: Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Posted on Sep 11, 2009
  • 401 Answers
SOURCE: I get water (alot) on shelves inside the frig. I
Sounds like the water drain for the freezer defrost is clogged. You will need to remove the back panel inside the freezer and check it. Sometimes it's just a piece of paper, or other wrapping that gets into it. Always UNPLUG the refrigerator first.
Posted on Jan 02, 2010
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from fridge
Generally, this problem can be solved by replacing the water filter. The water filters have o-rings that self seal when installed. If you keep the same water filter to long those seals will start to leak. Fortunately for us, the water filter housing is right over the drip pan, and when it leaks it conveniently goes there.
To make sure take off the toe panel to the frig. If you have problems taking the toe panel off don't worry, they need to be yanked. Start on on side and really give it a tug. Once you get that off you will see how it clips in and you can remove the other side with ease.
Now, if it is not leaking currently, have someone get water from the dispenser while you are on the ground watching. You will be looking at the filter mind you, underneath the frig. You should be able to see it dripping right into the pan.
Now of course you could have another leak, but that is most likely what has happened. Passed that, you will have to see the leak to know what is leaking. You can get water from the dispenser, but if that doesn't work you will need to wait for the ice maker to make some ice. Then you can see if that is the problem.
To simply cut off the water supply to the ice maker you would just need to turn the ice maker to the off position. Then it would no longer ask for water :)
If you need anything else let me know! good luck!
May 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
