SOURCE: How to downgrade my new laptop from Vista to XP it
you will need to reformat the harddrive in order to do this.put the windows xp installation disk in and boot to the cd go from there to reinstall windows xp. be sure to backup your files you may want to keep
call me for help
my name is marc
215-729-1745
SOURCE: Not installed os in my loptop
http://www.computerworld.com/s/article/9040318/FAQ_Giving_up_on_Vista_Here_s_how_to_downgrade_to_XP
http://www.computerworld.com/s/article/9108198/Microsoft_offers_free_Vista_to_XP_downgrade_help
Obviously, the most convenient way to downgrade is to do so without reformatting. In order to do that, you need to have a real retail CD of Windows XP. If all you have is a recovery disk that came with your computer, you’re not going to be able to do it this way. You will need to reformat.
To downgrade, use the following as a guide:
fixmbr
cd \
ren windows winvista
exit
SOURCE: hp pavilion dv6 screen went
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also connect aan external monitor to confirm if the PC is working or there is a fault in the display section or LCD. If so the linking cord to the display or the power supply or drive can be faulty. check the battery voltage, check the adaptor voltage on the terminal. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect. If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed. Thank You for using Fixya
SOURCE: hp pavilion dv7-1129WM has black screen and
its aproblem with the battery.change the battery and it will work fine.
SOURCE: HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
