Question about Xerox WorkCentre M-24 Color Copier
Fault 004-347 after change belt - Xerox WorkCentre M-24 Color Copier
I replaced my serpentine belt on a 2007 mazda 5 and now my check engine light is on what can i do to fix the problem
Get the fault codes read to find out which sensor is throwing the fault as you may have knocked one changing the belt or the fault could be unrelated
Dec 29, 2015 | Mazda Cars & Trucks
There is a beeping sound comes on when moving, changes tone when brakes are applied and stops when stopped?
it could be a seat belt alarm with belts not connected properly
run the fault codes or see a service dealer center for a diagnosis of the fault
Nov 08, 2015 | Cars & Trucks
Peugeot 406 hdi faults
Cam belts are due every 120,000km on peugeots. You should be fine for quite a while.
Sep 07, 2014 | Peugeot 406 Cars & Trucks
Need how to set timing belt on kia optima
I had 2006 kia optima 2.4 liter LX, I drove 150000 miles plus, it was over 100,000 miles I changed timing belt, and AC belt, alternator belt is still ok, but it was my fault, I did not change crank shaft balance belt, it next to timing belt, this very important, timing belt and crank shaft balance belt must change same time, you set all mark the same positions, you can see all clear marked
if you had OBD2 scanner is helpful to read all faulty codes if you do it your self repair
if you have any problems about KIA optima, please post on any websites, to share some ideas to other KIA optima owners, like me, I change oil every 2500 miles to make my optima runs smoother
automatic transmission fluid change every year if you put high mileage on your car, optima had hard time to find it own part some time, radiator hoses are still good condition and had hard time to find in any auto part stores in my home town, good luck and thanks for sharing.
Jul 27, 2011 | 2006 Kia Optima
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
Change moter alt belt keeps breaking
Hi the altenator belt? if it keeps snapping then your altenator is rather starting to seize up or its not fitted correctly, normally if its squeking its to loose.
Spin the altenator by hand and see what it sounds like, if its hard to turn or noisey that the fault.
hope this helps.
Jan 16, 2010 | 2000 Kia Sephia
Engine cuts out while driving main dealer has already changed timing belt but fault occurred again after 2 weeks driving. Now no error code recorded by the ECU and fault is no longer presenting. Model type...
Hi,check for all the sensors on the engine,may be one has been disconnected ,the ECU will not record any fault,sensors can be disconnected ,due to,when the mechanic has changed the timing belt,look for it.Hope that solve your problem
Sep 10, 2009 | 2002 Nissan Quest
Dryer wont spin, I changed the belt it spinned that day, but when I used it the next day it didnt spin.
Possible cause below:
Belt not in tension or not installed properly.
Faulty motor.
Drum is locked.
Other unrelated fault that had shown shortly after replacing the belt.
Regards
Jul 19, 2009 | Kenmore Dryers
Xerox WorkCentre M-24 Color Copier Logo
140 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
