Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
BOSCH SHY56A05 Dishwasher LED screen does not light up
Hi, I have a BOSCH SHY56A05UC/14 DISHWASHER and when I push the ON/OFF button the LED screen does not light up. Breaker Box and Fuse is good and has been tested. This issue happens 4 times out of 5 because the LED lights up once in awhile. So when the LED finally lights up the dishwasher works absolutely perfectly like there was no problem at all. I am clueless why it's not working all the time. I appreciate any help on that problem. Thanks.
Dave.
  • lbunbury Dec 24, 2008
    I have the same problem! What can we do?
  • 51 Answers
SOURCE: Bosch Dishwasher classixx blows fuse when turned on
No don't hose it out. That will only make things worse. There are a good number of reasons why it may be blowing the breaker. You will need to meter out the different parts to check for a short. My guess from you description is that the softner unit has broken / leaked and gone into the main pump. You will need to replace both if thats the case.
Posted on Jul 25, 2007
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
  • 409 Answers
SOURCE: Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Posted on Sep 13, 2008
SOURCE: Our Bosch dishwasher will not
can you hear humming?try taking out the screen filter and there is a torx screw that you can see, remove the screw and see if there is anything in there when you remove the panel.you will see the drain impeller try turning it by hand. if it is siezed then you will have to replace it.try putting it back together and try it again.
let me know.
Posted on Nov 11, 2008
  • 10 Answers
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Posted on Jun 26, 2009
Bosch dishwasher shy56a05uc 14
I would assume it would leave water in the machine. some machines have this as a function. it is used to keep water in the drum to stop items becoming excessively creased. it is mainly used if you are not going to empty the machine for a while. you should be able to press the cancel button again to start the draining process.
Dec 13, 2013 | Dishwashers
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY56A05 Dishwasher was running even with door open
find out first from boschwhats covered and whats not. i think bosch has a 2year iw on electrionics, and some models has a recall, go to thermador .com and you will be able toget the # to bosch which is the same company and give them your model # and serial # they will tell you whats is covered and whats not.
Jul 29, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Jan 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
54 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
