Question about Microsoft Xbox Console
I have blinking green & red lights on my xbox & its not a 360
First it boots, then turns off it does this a couple of time then it goes into the red and green flashing with no video output. the hard drive boots, the dvd spins but that's it, any suggestions?
  • 1 more comment
  • Anonymous Nov 22, 2008
    My original xbox, not 360 "tries" to turn on 2 times in a row and on the 3rd time it flashes red and green.
    I have not modded it in any way!!
    On occaision it works fine, but wen i go to chage discs it starts flashing green and red again.
  • sad2006 Nov 24, 2008
    mine wont even give me video not even once it was dropped once though and i cant figure it out
  • eastsideking Dec 26, 2008
    one day i was playing my xbox,(not 360).I turned it off then i turned it back on then all of a sudden the light starts flashing red and green i got realy angry.one second i was playing the game the next second
    Problem Solver:
  • 24 Answers
Have u attempted to mod it? if the bios is corrupted/destroyed it will FRAG "flash red and green" and if thats the issue, you may need a modchip to revive it. can you post more?
Posted on Nov 13, 2008
Your Xbox may not be plugged in right, look at your manual at the installation instructions
Posted on Nov 08, 2008
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Xbox one blinking red light.. 1 not 3,, first time i seen this, fixed many ps3 ylod,, is it the same fix? looking for help here or a good link on repair info
When you get one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Feb 06, 2010 | Video Game Consoles & Games
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Red light on first xbox
Cracked solder points try turning it on with the fan unpluged and wait untill you get the 2 red rings lights 1 and 3 then wait until the xbox shuts off then wait a couple of min. then reconnect the fan and turn it on to see what happends.
May 23, 2009 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
I get red rings when i turn on my xbox 360
Help with xbox 360
try pressing and holding the bluetooth button on your 360 while doing this turn your xbox on and keep holding until it boots completely even if it does not make it to the boot screen just keep holding it until you think the time would have passed for it to boot up. power off your xbox. wait about 5 minutes and then reboot believe me this little method fixes alot of the xbox problems so it makes me wonder if some of the error codes are really correct. one more thing i strongly recommend the use of a cooling device for the 360 which ever one you choose
May 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
316 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
