Question about Memorex MMP8565 MP3 Player
Wont charge when I plug it into the computer the screen goes off. I also cant find my book so I don't remember which button to press to charge it
  • jonathan Feb 16, 2012
    I can't find my bood
    1. how do I recharge the player?
    2. When I plug it into the UPC it turns off
Hi my Samsung R730 wont power up after shutting down when battery was low have tried pluging it in to mains and pressing power button but nothing works
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 13, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
S/nLUWCX08006942365AC1601 WONT BOOT UP
Mar 30, 2012 | Gateway Computers & Internet
Gateway notebook wont boot up
Comp.will not boot starts screen no signal goes off
Mar 29, 2012 | Computers & Internet
Toshiba wont turn on
Mar 28, 2012 | Computers & Internet
Wont turn on
My screen is black
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.If it seems like the laptop is up and running but the screen is not displaying anything then the issue is with the screen. Take a flashlight and shine it on the screen and look very hard and you might see the icons or something very faintly on the screen. If so, your LCD Inverter needs to be replaced. It is located at the bottom of the screen and covered by the strip that goes around the screen. IIf you don't see anything on the screen then try plugging an external monitor to the laptop. I can be any kind of monitor, even the old big fat crt's as long as it has a vga cable that can go into your laptop's vga port. If you see the image on the external monitor, that means your video card is good and the screen needs to be replaced. Sometimes you might have to hit the FN key plus one of the F1 thru F12 keys to get the image to display. The correct F1 thru F12 key will either say CRT/LCD or it will have the icon of a display on it. Press and Hold the FN key then hit the correct F1 thru F12 key. This will toggle the the image to display either on the computer's screen, the external monitor screen, or on both screens.
Mar 25, 2012 | Computers & Internet
How do I find the security code for my Matsui VP 9606 VHS Player
Try this
Unplug from wall for 30 minutes, then plug it in again. Power it on, and then PRESS CH UP & REC/QTR BUTTONS TOGETHER on your machine ~ (haven't tried it via the remote) Should then come up as "Pin OK" on the blue screen
I don't think it will give problems after that. Should stay unless you unplug for 30 minutes, the buttons won't reset the video.
Nov 17, 2011 | Video Cameras
How to finalize the disk without the lcd screen it broke
If you have the mativa program you can hook the camera directly to the computer and not need to finalize the disk,
I checked the book and the steps to finalize are,
(1) DIAL ON SETUP AND TURN ON CAMERA
PRESS THE ARROW RIGHT ON THE CONTROL BUTTON THIS PUTS IN ON FINALIZE
PRESS ARROW UP ONCE, THIS IS THE OK BUTTON
PRESS CENTER OF CONTROL PUTTON
SET ON STABLE SURFACE AND MAKE SURE YOUR BATTERY IS CHARGED, OR CAMERA PLUGGED IN,
PRESS CENTER BUTTON AGAIN
IF YOU WANT TO SEND ME AN EMAIL I WILL TRY TO COPY YOU A PAGE OUT OF THE BOOK, MARG
Nov 17, 2008 | Sony Mavica MVC-CD400 Digital Camera
Memorex MMP8565 MP3 Player Logo
26 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
