Question about Intex Pool & Spa
Bypass timer on intex pool pump - Intex Pool & Spa
SOURCE: the pump/filter combo for my easy set pool doesnt
There is an air/suction leak on the inlet side of the pump or, if this is an above ground pool, the pump is not set below the level of the pool.
Posted on May 31, 2009
  • 93 Answers
SOURCE: intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Posted on Jun 16, 2009
SOURCE: need instruction manual to set up my pump for intex easy set up
The correct website is intexstore.com
on the right side, about half way down the page there is a blue box that says instructional set up video and manuals. You then click on pumps and on your model, and you can open it there.
Posted on Aug 24, 2009
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
nlc0
  • 3 Answers
SOURCE: How do I hook my 633T intex pump to my 15'x42
I have a 16 x 48 intex pool with the 1inch inlet and outlet. I purchased the intex 4000 pump. The attachments are too big for the inlet and outlet so i then purchased the adapters through Intex corp.com. The plungers that come with the pump are very noisy and allow air to get into the pump. I removed them and hooked the hoses up to the adapters directly. That worked as long as the adapters were new. This year the seal comes loose and allows air to get into the pump. I even tried allowing the top nut to be loose to allow air to escape. This year nothing works. The pump is just too strong for the holes. I was considering cutting the holes bigger and glueing seals on there but i was concerned about creating weak spots in the pool. I am tired of spending money on it so i did the redneck thing. I can say that because well, you might consider me one. I took the inlet hose off the connector and plugged the hole with one of those little black things. I took the hose and run it up through the hole in between the liner and the poles and down into the pool. If you run it over the top it will not work correctly. Take the hose and tie them together between the two sides as best you can to keep the hose in the pool. If you look at the smaller intex pools that dont have holes, that is how they have the pump hooked to the pool. VOILA! You have an airtight inlet to the pump. You do not need to do that to the outlet because its not sucking water its just pushing it. So, just hook the hose up as you wish. When you need to clean the filter, I put wash clothes in the hoses to plug them and voila. No air gets into the filter. Done! It is actually keeping my pool clean this year. Also, i purchased one of those aqua vacuums and it does work great for this pool. Once you get the big stuff, sweep it with a pool broom and the filter will do its job. You can vacuum these pools with the filter type pumps. Next time, i will purchase a sand filter and be done with it. Happy swimming with less work
Posted on May 22, 2010
Why does my Krystal Clear pool pump click on and off while displaying 88? diffently clicks off nad on.
IF YOU HAVE A TIMER IT WILL CLICK CODE AT ANY INTERUPTION OF POWER THIS COULD BE YOUR END OF CYCLE OR LOW VOLTAGE MAKE SURE PUMP IS WIRED CORRECT
Aug 03, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Pool pump motor does not turn pump when timer trips
does it hum at all.. turn the impeller with a small rod se if it will sart up..
Dec 31, 2013 | Intex Wet Set Water Filtration Filter Pump...
Runs
pool pumps should run at least two hours for every one hour of pool use , this should be doubled if pool recieves a heavy useage of more than three swimmers timers on most of the intex models are set with trip pins , in towards center to be off and out from center to be on
Jul 13, 2013 | INTEX Sand Filter Pump
Intex sand filter not working
timer set to bypass? try ON if all good , timer is bad look for water damage sometimes water gets inside and rusts stuff all up
Jun 17, 2013 | INTEX Sand Filter Pump
I bought the Intex 2100 gpm sand filter (16") and pump from Amazon for $199. I turned it on about maybe 6 times. When first tried it just made loud grinding sounds no pumping, then would shut off....
these pumps should run 24/7 as they are SMALL,
try contacting Amazon. see if you can get a replacement pump, pump only. also, see my tips and tricks keeping pool from turning green
Jun 06, 2017 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
I have a question regarding the Intex Saltwater pump. If you cannot unlock the keyboard and set the salt timer will the plates on the ionization system still work or are they disabled unit the timer is set...
Must set the timer!!! It will not generate chlorine without setting the timer...
Try these instructions to unlock your timer and set the unit... If this helps, please rate the information.. Thanks and good luck!
Jul 23, 2011 | Intex Automatic Salt Water System for ...
How oprates the timmer in my 2500 gph intex filter pump
When the timer mode is set it will only run for the hours you have the knob positioned to. It will then shut off. You will need to restart it everytime.
Jun 21, 2010 | Intex Krystal Clear Model 635 Pool Filter...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Intex pool filter is putting out dirty water, and i have just replace the filter
make sure the filter is seated properly and all the seals/o-rings are in place. Look for any potential area that dirt/debris would bypass the filter.
Nov 24, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Pool & Spa Logo
75 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
