Question about Yamaha CDC-565 5-Disc CD Changer
Player won't read cd's keeps opening door
Everytime I try to play a disc the door will open.I try to switch to any of the five slots and it almost always reads open and will not play
  • 30 Answers
This model has a belt used for loading the cd mech, after you push play if the belt is slipping or gone,the door will open, if you take the cabinet off eith power off and traopen, look at cd mech you see a belt, it may be loose or gone
Posted on Nov 05, 2008
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Jan 19, 2012 | Panasonic Audio Players & Recorders
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Feb 11, 2010 | JVC HX-D77 Shelf System
The disc door frequently will not open and now it
One of the things you try for this , is to remove moisture that has collected in the machine, this could be due to it being in a cold room,or not used for sometime.
bring it into a warmer environment switch it on and leave for 2 hrs then retry your discs.
Also check the region on the dvd matches that on the discs.
Please see your manual for discs your dvd won`t play,also about finalising.
Oct 20, 2009 | Televison & Video
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
Fisher CD-RW1000 2-Disc CD-dvd stuck in player
hmmmm.... try to take off the cover of your dvd player and observe it.(if you try my advice, try it in your own risk and with caution) then check the tray maybe there is something got stuck in there and also check the gears, if nothing, a belt just came off. check the motor too, I guess It has 2 switches too. clean them up. and then try to power up.
note:
(keep you fingers away at the power supply section)
Jan 29, 2008 | Fisher CD-RW1000 2-Disc CD Recorder
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Dec 16, 2007 | Pioneer DV-C36 DVD Player
CD player
Could be the classic dirty lense syndrom... If you know how to get to it, expose the laser lense, and gently brush any accumulated dust/dirt from it. There might be multiple slots, but only 1 lense. If you have a cd cleaner available you might want to try that out first, it doesn't always do the same job, but it can save you the risk of something else happening when you open it up. Good luck
Dec 09, 2005 | Panasonic SC-AK70 Shelf System
Yamaha CDC-565 5-Disc CD Changer Logo
442 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
