SOURCE: Have had 4 Neff oven elements in 2 years.
As barkencoa says, cheap elements from ebay etc don't last long. I proved this myself when my Neff B1320 fan element blew. I replaced it with one for about £10 from ebay. It lasted about 11 months. Last replacement I fitted was from Currys Partmaster. So far it's ok after 6 months.
SOURCE: we have an Gaggenau EB 290 oven and the error code
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
SOURCE: When my oven almost reaches
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
never heard of an F1-2 code but they make new stuff everyday. Go to this link to get tech data: Maytag library of manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: HOw do I remove me
Open the door to the first stop(where you put it for broil)and pull the door up off the hinges pulling in the direction the door is slanting up.
