Question about HP Digital Sender 9250c scanner Printer
HP 9250 user gets 49 FS04 error when trying to use scanner
EPIJAB
  • 89 Answers
SOURCE: 49. 2F05 SERVICE ERROR
The error code series of 49 refers to a firmware issue but given the paper feed problems it seems more like a fuser error.
The solution for the firmware error code is to turn the printer off for 20 mins or so. Make sure all paper fragments are removed first.
The dirty marks on the right side could be from the toner cartridge or the fusing unit. You can look at at the toner and see if there is still al ine down that side of the green drum unit or just try replacing it and see if the problem continues if so you need to look at the sides of the fuser.
Posted on Feb 04, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Posted on Nov 24, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
SOURCE: HP LASER JET ERROR 49
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01571503
Posted on Jun 23, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
I keep getting error code NVRAM err=0x10, what does this mean?
HP Printers 49.XXXX Service Errors ' Market Point's Tech ...
blog.marketpoint.com/2010/07/29/hp-printers-49-xxxx-service-errors/
Jul 29, 2010 - In this article, I'll discuss the meaning of the error, what causes it, and gives ... changes with the firmware or other parts to prevent the error from recurring. ...fixes for a few printers and was surprised to see several 49 errors being ... try a cold reset or NVRAM initialization (see service manual for details).
A wifi spot named "NVRAM WARNING: ERR = 0x10" - DealExtreme Forum
club.dx.com/forums/forums.dx/threadid.1136935
Mar 11, 2012 - A wifi spot named "NVRAM WARNING: ERR = 0x10" ... It has the sameerror, both in wifi settings and in the wifi Analyser app. I did obtain the ...
57.1 printer error - HP Support Center
Dec 17, 2015 | Office Equipment & Supplies
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
HARD RESET hp laserjet m175nw ?
Try this:
1- Make sure printer is off.
2- Press and hold Red X and Right Arrow key.
3- Switch printer on (Red X and Right Arrow still pressed down)
The goal is to get the printer display a "Printer Settings Init" message. Release the two buttons when you get this message. If nothing happens, try the procedure over again.
May 14, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
Error 49 hp laserjet 400 color m475dw
HI there, this seems to be an issue with the network if you do have a boxee try disconnecting it and check if thats the issue you need to contact boxee or try updating you router hardware .it may also occur if an apple TV is connect .
Make sure if you do ahve a Boxee you need to assign it to the network as it would send multiple packet data which would lock the printer which in turn makes it to reboot
Apr 05, 2013 | HP LaserJet Pro 400 color MFP M475dw -...
HP LaserJet 3055 All-In-One Printer "49 error turn off"
The 49 code is related to one of three things on this unit.
1. You accidentally used a refurbished toner instead of one directly from the manufacturer which tends to cost a bit more. The certified one from the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
Mar 22, 2013 | HP LaserJet 3055 All-In-One Printer
Error 49
If the error can be reproduced, use the following sections of this document:
  • Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Nov 03, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
The error "49. FF05 SERVICE ERROR" is displayed on
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
Oct 26, 2010 | HP LaserJet P3005d Printer
HP Digital Sender 9250c scanner Printer Logo
289 people viewed this question
Seeker5211
Seeker5211
