Question about Olympus SuperZoom 80G 35mm Point and Shoot Camera
The camera is not gettin started
Well my camera was in a very good condition till yesterday but today it not working at all.actually yesterday my mom double cliked the photo button simultaneously and jus then a voice started coming and then it stopped and now my camera is not getting started.i have taken out the film and removed the batteries.plz help me as soon as you can.
neta
  • 852 Answers
SOURCE: When I printed the photos none of them was even close to film-based photos
Try using a good program like Photoshop and when you adjust for printing...make sure you DO NOT subsample the image so it can fit on a 4x6 photo paper page. What I mean by that, is in fact reduce the image to fit on such a small page but do not kill the resolution.... In Photoshop, you would open up Image Size under the Image menu and turn uncheck resample image...as you adjust for paper size...you will notice that your resolution stays intact on the top of the window. I assume that is your problem since the 2500 is highres and should give you fantastic results in a 4x6 format.....
Posted on Sep 06, 2005
  • 479 Answers
SOURCE: Olympus FE 280 digital camera
remove the card and see if you still have the same problem... if so then repair. if not then it is the card
Posted on Sep 03, 2008
SOURCE: There appears to be a loose connection . The camera stops working
i have an olympus fe-100 even with a new battry when swith on the lens move out & back in , then two light green & orange flash 10 times & stop
Posted on Jan 30, 2009
  • 175 Answers
SOURCE: film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Posted on Mar 03, 2010
Geekman
  • 32281 Answers
SOURCE: Plz help. I am sick over this. My OLYMPUS SP-800UZ is still plugged into my pc. I dare not do anything till I talk to you.
On your computer there is a Recycle bim icon. If you did not empty this Recycle Bin the when you open this Recycle Bin you can left click on the folder you had deleted then click on File then click Restore.
This folder will then be returned to its previous location with your photos.
Posted on Jun 03, 2012
I have a 70 cc coolster dirt beike that wont start but its gettin fire,gas and has good compression
If its getting fuel, spark, and has good compression there's only two things left. Either no or very little air or a blocked exhaust.
Jan 03, 2015 | Motorcycles
Im using windows 7 for past 2years!! From today moring i getting error reporting CONSIDER REPLACING YOUR BATTERY!!! Till yesterday it was working fine!!!
This is easy ... you should consider replacing your battery. The reason is your battery is getting older and it is deteriorating. Batteries start deteriorating as the moment the close the package and call it a battery. Be thankful that your battery is cooperating with your operating system and is giving you ample warning as to its condition.
Thank you for your question @ FixYa.com
Sep 18, 2011 | Computers & Internet
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
I have a 96 Plymouth Voyager Mom Mobile that has been leaking oil for years - she has a hard 161K miles on her and I just want to keep her going until tax refund time. All of a sudden she gone from 2 qt a...
use stop leak oil additive and heavier oil.vibration and
residue sounds like wheel bearing grease,your R front wheel bearing could be shot causing both conditions
Oct 21, 2009 | 1996 Plymouth Voyager
Laptop went blank suddenly
chck the memory ,,and reboot the machn..thn c,,if nt tht remov the memory n clean it n put it bck and try
Aug 12, 2009 | Dell Inspiron 1525 Notebook
Vdr d50p says disc is incompatible worked fine yesterday today i get this message. still able to take stills on sd card but nothing from dvd
if u bought the dvd+r it wont work ull need the dvd-r so it can work i had the same problem till i bought the right dvds
Jul 08, 2009 | Panasonic VDR-D300 DVD Camcorder
E:61:10 problem
I had the same problem, however mine was showing a slightly different error message it was E:62:11. Anyway a few of the websites online had postings from different people who had experienced the same problem, and they said to hit the camera lightly on the side where the cameras battery is located. I tried this right after I turned the camera on while the camera was booting up and it worked. So you can try doing this -- hopefully this helps
Feb 05, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
Image quality wit logitech quickcam chat
Normal 0 You need to go to the manufactures site and download the XP or VISTA driver for the camera. Then follow the info below to install the program.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jul 29, 2008 | Logitech QuickCam Chat Personal Web Camera
Puk codes
need a puk code as my phone is locked an i called testra yesterday and they said there systems are down and to call todaY WELL I DID AND THERE NOT EVEN OPENED. i cant wait till monday i need to use my phone now help plz'''
Jul 12, 2008 | Computers & Internet
Olympus SuperZoom 80G 35mm Point and Shoot Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
