Question about Hoover Vacuums
Vax big bubble sparking motor
It sparks from motor & smells of burning
5 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: Vax 2000 trips electrics
Try the reset drive belt brush button - you'll find it underneath the main power switch on the handle. Also check the brush isn't clogged, by the sole plate by tipping it over and undoing the screws on the bottom place where the beater bar is.
Posted on Apr 11, 2009
  • 97 Answers
SOURCE: my hoover dual v steamvac make loud noise and sparks
unfortunately the motor did go out on this machine. the commentator brushes and the armature are burnt and the motor or the machine will have to be replaced
Posted on Jul 29, 2009
  • 294 Answers
SOURCE: vax hoover bagless, there is a burning smell
Most common burning smell is the belt in the power nozzle. check & replace.
Posted on Oct 11, 2009
  • 78 Answers
SOURCE: Motor problem
nothing you can do im affraid its the motor armature so unless it can be stripped down then you will need to replace the motor i would get a price for the motor to decide if it is worth doin sorry.
Posted on Oct 30, 2009
Why does my vax power 2 cylinder hoover make a noise and smell of burning rubber when I turn it on we have cleaned inside and out and all filters
That is the smell of perhaps burning insulation when there is excessive current going into motor. If something in unit is binding the motor will not spin fast enough, generate less back emf, use more current, overheat and burn out!!!!!!!!!!!
If it has a drive belt and that is rubbing up against something and not turning properly that will also cause the smell.
Do not use unit in this condition -you risk permanent damage.
Aug 31, 2015 | Hoover Vacuums
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Vax keeps turning off after 30 secs some times smells of burning
1) Test the belt for worn
2) Test the power cord for wire burn, or broken
3) Test the main motor, for bearing, LUBE , winding defective or burn.
gOD BLESS YOU.
May 09, 2012 | Vacuums
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
Motor is making a knocking noise with a burning smell and sparks can be seen when switching on
Sounds like ur FiLTER is CLOGED!
Air was blocked going in the motor thats why ur smeling smething burning, means ur motor is starting to overheat!
Spark in the motor is NORMAL when the CARBON BRUSHES is touching the ARMATURE!
My suggestion is to CLEAN & WASH the filter or buy a NEW one!
Hope that cleans evrything on ur probs!
Dec 04, 2010 | Dyson DC08 Cylinder Bagless Canister...
Vax hoover bagless, there is a burning smell coming from it
Oct 11, 2009 | Hoover S3639 WindTunnel Bagged Canister...
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Smells like the motor is burning. observing sparks. It the motor cooked and is it just time for a replacement?
If you're observing sparks, then yes, just get a new one. With the low prices of good vaccuums its not worth starting a fire with your vaccuum. If it just smells like the motor is burning, check the belt and make sure its rotating freely and if you have an attachment, make sure the brush on the vaccuum is not being stopped while using the attachment. However, if you are seeing sparks,,,, definately time to junk it
Aug 20, 2009 | Sharp Twin Energy EC-TU2603 Bagged Upright...
Motor
you have it right either the motor is going out or water got in there causing it to spark and smell.sorry.lease leave feedback...pete
Apr 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
309 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
