Question about Zanussi Ovens
Replace grill element for Zanussi ZOB 551
The grill has stopped working properly. I can see a screw in teh top of the oven which when released allows the grill elemet to drop, it is attached from what i can see by 4 nuts at the bock of the oven (top). How do I replace? It is just a simple unbolt and refit or do I need to take oven out etc.
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: Need English user guide for Zanussi zob 662 x
    zanussi built in single oven outer glass door has just exploded any similar problems or reasons for this
    Posted on Nov 14, 2009
    barkencoa
    • 3463 Answers
    SOURCE: Dead oven despite element replacement?
    If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
    What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
    Please rate my solution.
    Thankyou.
    Posted on Feb 02, 2010
    barkencoa
    • 3463 Answers
    SOURCE: zanussi electric double oven. Top oven not working.
    It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
    Hope this helps.
    Posted on Feb 10, 2010
    barkencoa
    • 3463 Answers
    SOURCE: the grill element has fallen down because the two
    What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
    Posted on Apr 06, 2010
    Fan and element not working
    hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
    open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
    Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
    My grill element on my zanussi oven, ZBF 260, has stopped working. How do I remove the faulty part so I can replace it?
    after isolating electric. remove oven from housing ( 2 or 4 screws) remove back of appliance to access retaining nuts .( disconnect wires noting terminal position). grill is fixed to roof of oven with screws remove these and take out grill. refit in reverse order remember to reconnect wires .
    Aug 24, 2010 | Zanussi Ovens
    The grill element has fallen down because the two
    Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
    Zanussi electric double oven. Top oven not working.
    Hope this helps.
    Feb 10, 2010 | Ovens
    Fan in main oven boken
    Sounds as if your oven heating element has failed. You need to fit a new one.
    Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
    Dec 31, 2009 | Zanussi Ovens
    I want to replace the top grill element in a zanussi zhq 575
    Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
    The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
    Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
    Fit new element in reverse order, it is a fairly straight forward repair to do..
    Plz rate my solution.Thanks.
    Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
    Zanussi oven not heating
    The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
    Jul 12, 2008 | Zanussi ZHQ575 Electric Double Oven
    Zanussi zbf 760 (9 yrs old now)
    This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
    Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
    Ovens Logo
    41 people viewed this question
    Top Zanussi Ovens Experts
    ashburton
    Flipper
    Level 1 Expert
    Are you a Zanussi Oven Expert? Answer questions, earn points and help others
