Savin CLP22 printer says to replace toner bottle?
I do not know where the toner bottle is located and what to order.
mitpatterson
  • 74 Answers
SOURCE: Waste toner bottle
Here is a image from the users guide showing where it is
Please don't forget the leave me feedback
Posted on Feb 23, 2008
  • 58 Answers
SOURCE: Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Posted on Feb 26, 2008
jaylex
  • 417 Answers
SOURCE: replace toner bottle?
Toner waste bottle located at the front of the machine where the toner goes. Open the front cover as if to replace toner. to the bottom right s a little clear plastic tank. remove it and vacume all the toner out of it then install it again this will make it work.
Thanks Jason
Posted on Aug 17, 2008
chad7houston
  • 62 Answers
SOURCE: Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Posted on Oct 09, 2008
vegakitten20
  • 685 Answers
SOURCE: Toner Cart chip reset for Ricoh Aficeo sp c400dn
try to unplug it and plug it back in this will reset it
Posted on Jan 04, 2009
How do i reset a fusing unit counter on a CLP22
Hi. First of all did you have a code to tell you to replace the unit? I would like you to put the old unit back in and see if it lets you restart your printer. If it comes back up you have a problem with the new fuser you received. Take a few seconds to compare the unit and make sure all looks the same. If it's a remanufactured some times little things like tabs and the such get bent or broken. It should reset the counter when you set the new one was replaced. Hope this helped. I do get a little wordy at times
Feb 04, 2015 | Savin GENUINE RICOH FUSER UNIT (402451)...
Savin 2406wd how to change waste toner bottle
Do not attempt this , call a qualified tech, the drum can easily be damaged during this operation
Aug 14, 2014 | Savin Office Equipment & Supplies
Where is the waste toner on savin 4051 sp
it's behind the front cover - lower right side...unlock the push/pull snap and side the bottle holder & bottle out of the front of machine. empty and reinstall.
Apr 08, 2014 | Savin 4051 Sp, Ricoh 2051 Sp, Copier W/net...
Black will not print on a savin clp22
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Oct 16, 2013 | Savin GENUINE RICOH FUSER UNIT (402451)...
My Savin 3515MF doesn't believe I replaced the toner. I have replaced it a few times, so I followed the same instructions as before but to no luck. HELP!! Please and thank you!
Try cleaning any excess toner from the sensors and any glass inside the same panel as the toner bottle hopper.(the glass slides in and out). Use compressed air around the area where the toner pours into the developer but be careful not to blow out the developer.
Oct 11, 2013 | Savin Copier Supplies; Toner for 3515,...
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
www.p4photel.com
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
147 people viewed this question
jasbo
jasbo
