Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
HP 6500 wireless printer making grinding noise
Making a terrible grinding noise when first switched on and when printing
SOURCE: grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Posted on Mar 25, 2008
  • 193 Answers
SOURCE: HP P3005 making grinding noises
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Posted on Apr 13, 2009
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
Morikvendi
  • 56 Answers
SOURCE: HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Posted on Jun 01, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Why does my HP Officejet 6500 Wireless printer make a chirping noise while just sitting idle?
Every once in a while the Printer goes through maintenance and calibrations. Is this occurring periodically or frequently?
Jul 18, 2012 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 wireless E709N makes a loud squeaking noise every time something is printed and is printing additional lines on the sheets of paper being printed?? Help!
Horizontal streaks across the page usually mean your cartridge is about to run out, or is at least dirty. Try cleaning the nozzles, though avoid doing this manually -- your printer should have a cleaning cycle.
The squeaking noise could be dust in your rollers. That can't really be fixed without major intervention that could throw something out of balance and result in many a paper jam. You can use a lint-free, static-free cloth to gently clean inside an unplugged printer, but it's generally not a great idea to mess around in there too much.
May 06, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless printer won't print quickbooks checks
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
Jul 13, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you print on both sides of a piece of
On the computer:-
Click on start-->control panel-->printers and faxes or printers-->right click on HP Officejet 6500 Wireless All-in-one Inkjet Printer.--> choose the print preferences option. Now you will see in the list of options there is some thing called depluex printing --> Select it and hit the apply button and then try printing.
It is actually a setting under the printers properties which needs to be switched on. Once you switch it on it will start working.
Let me know if it works.
May 07, 2010 | HP Officejet 6500 Wireless All-in-One...
HP 6500 WIRELESS WON'T PRINT MS WORKS SPREADSHEET
Make certain all HP Drivers and Firmware are up to date. HP has diagnostic software free.
Feb 18, 2018 | HP Office Equipment & Supplies
May 29, 2009 | HP Office Equipment & Supplies
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
214 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
