Question about BenQ MP523 DLP Projector
BenQ Hi all.. i have a problem with My benQ mp523.. when i push power button, it appears to turn on for a while (2-5 second) then turn off.. after turn off, the temp and lamp indicator turn to red, and the temp indicator blinking... was there anyone here who know what may have caused this? is there anything need to be replaced or it is something that i can fix my self? please help guys.. Thanks very much..
    Top Expert:
  • BenQ Master
  • 12,962 Answers
Check the bulb and/or bulb fan for proper operation.
Posted on Aug 03, 2017
4 Suggested Answers
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Posted on Apr 10, 2009
projdoc
  • 2237 Answers
SOURCE: I have an Benq MP610 that the power indicator
may be thepower supply. if the caps are dried, it won't deliver sufficient power.
Posted on Nov 12, 2009
SOURCE: Projector shuts down ca 20 sec from start.
I have the same problem, however, my lamp wasn't replaced. Projector working great, just started today. Filter cleaned, reset lamp time, neither helped. Any luck yet?
Posted on Dec 25, 2009
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
How to reset lamp hrs.
hi
you can reset the lamp hour by the following settings
1.Power on the projector
2.Press the EXIT button on the projector for 3 second to display the total used lamp time
3.Press the MENU button on the projector (adjustment message will appear
4.Press the LEFT ARROW or RIGHT ARROW button to to reset the lamp hour
5.Press the EXIT button
ok
Jan 18, 2011 | BenQ PB2220 Multimedia Projector
White pixels forming on screen and increasing in number. Slight distortion in other spots pixels are extremely bright but small.
This is a problem with the internal DMD chip which needs to be replaced.
Contact BenQ Service,should be covered under warranty.
Samir
Aug 22, 2010 | BenQ MP523 DLP Projector
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Nov 21, 2008 | BenQ FP91G+ 19" LCD Monitor
Intermittent Power
that means the power button is bad or some wire on the button is loose
Aug 31, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
BenQ MP523 DLP Projector Logo
26 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
