Question about Solar Pool & Spa
Does anyone have a manual for the solar controller sc2d?
I'm renting a house with a solar heated pool, but amn't sure how to work the solar controller. Does anyone have a manual I could see please. Thx
3 Suggested Answers
  • 139 Answers
SOURCE: Filter clicks, but won't turn on. Pool lights
put your aqualink into service mode. then select components manually this will override any pre-programmed options
Posted on Jul 21, 2009
  • 128 Answers
SOURCE: I have a Compool lx220 control for my pool solar
Check the valve actuator toggle switch. It is 180 degrees out. If the toggle switch is in the up postion flip it down or vise versa.
Posted on Aug 30, 2009
Black water coming out of returns from solar panels on roof of my home. Panels are 15 years old and there was frost in San Diego the nite before it happened
How do solar hot water panels work? - Explain that Stuff
www.explainthatstuff.com/solar-hot-water-systems.html
Jun 2, 2015 - Photo of solar hot water panels on house roof. ... What if you cut the top and bottom off a plastic bottle and fitted pipes at each ... This is the technical name for the big black panel that sits on your roof. ... The heat is then passed into the hotwater tank, and the cooled water (or fluid) returns to the collector to ...
Solar water leak - YouTube? 1:46https://www.youtube.com/watch?v=WaWkzfs6bikMay 22, 2012 - Uploaded by EnovativeGroupLeaky solar system, enovative group investigates... ... Solar water leak ... Solar Water Heating Panel and ...Pool Solar Panel - A How to Fix - YouTube? 2:50https://www.youtube.com/watch?v=f_KzEsxQhbEJul 7, 2012 - Uploaded by Clive WoodrowEasy and cheap way to fix a leak in your pool solar panel. ... The pipe (to carry the water to and from the ...
Dec 21, 2015 | Solar Pool & Spa
Why is my GL235 solar heater control panel not heating the pool. The heating light is on and the power light is on. What should we do.
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Nov 15, 2014 | Goldline Solar Pool Control Package Gl-235...
Problem with jandy rs 4. Pool heat pump Is running. We didn't turn it on and the heat pump light on the control panel is not lit
Does your pool gave an attached spa?
IF it does have a spa, dies it also have a spa side remote?
If so the first step would be to unplug the spa side remote from the back of the board.
If the issue stops then you need a new spa side remote if it persists then it nah be be main circuit board or relay for the heat pump.
Nov 01, 2014 | Jandy AquaLink RS 4 P or S OneTouch Pool...
Aquatherm pool heater
make sure it is connected to the solar to get it to work
Jan 06, 2013 | Jandy Digital PoolSpa Control w Actuators...
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
Have a supreme Solar - Solar conroller for swimming pool. Roof indicator light is flashing and system wont turn on, (not even in manual mode) Pump working OK though. What does this mean
it sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
Nov 08, 2009 | Solar Heating System For Swimming Pools
Jul 21, 2009 | Jandy Aqualink Rs4 One Touch Control...
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Fafco Solar Panel system - how to bypass sensor?
I would, put a quarter turn ball valve in the sensors place.
Apr 14, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Pool & Spa Logo
470 people viewed this question
Top Solar Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Are you a Solar Pool and Spa Expert? Answer questions, earn points and help others
