Question about LG Televison & Video
LG 42PG10DC Antenna input signal is not compatible, how it work to my current antenna
I got signal, but black & white with motorboating sound
SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Posted on Sep 19, 2007
tvtechnician
  • 105 Answers
SOURCE: red pixels
you will need a professional to service your tv. basically the tech needs to  connect an osciliscope to the y susatain board and adjust the voltages on this board. most plasma tvs will need this done about every seven years because electronic components tend to lose their value over time. this is called electronic drift.
Posted on Oct 24, 2007
Drummernick
  • 440 Answers
SOURCE: antenna setup for digital signals is grey and not available
is scan for chs lit up in options scan 1st ok
Posted on Feb 11, 2008
SOURCE: have audio through all inputs except cable
The solution recommended will take a considerable amount of time. We will get around to it over this weekend or next weekend. It's not so bad doing without the background noise of the TV for a while.
Thank you for your recommendation to repair and detailed explaination of the procedure.
gcdavdenver
Posted on Jun 07, 2009
  • 36 Answers
SOURCE: lg 37le2r will only show black and white picture.
I've encountered that experience before it needs some technical knowledge because the raster for rgb on your lcd is going bad and the video signal out put cable is mis aligned get someone to re align the raster and your video signal output cable
Posted on Jan 09, 2010
Testimonial: "thanks for this it will help a lot"
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Sat nav and radio not working
Good Afternoon Michael
Sounds most likely to be an antenna issue. Most everything going into the radio needs an antenna to be picked up. Sometimes, a station or two might still be heard above the static if they are local and fairly strong signals.
If you can get normal sound from other inputs, like MP3 players or CDs, then the amp and output parts of the unit are fine, and it's an issue of getting an input signal to use.
If you have the tools, pull the stereo head unit from the dash and make sure the antenna input cable(s) are firmly in place. Likewise, depending on location, you can likely get to the base of the external antenna, where the other end of the cable plugs in, and make sure it's in snugly.
lacking the tools - you can talk to your dealer or a local car audio place. They'll likely have the tools, and a check for antenna cable connection would not likely be too expensive or time-intensive.
Good Luck!
Nov 18, 2015 | Mercedes-Benz C-Class Cars & Trucks
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
Feb 10, 2015 | Vizio S5430W-C2 54-Inch 3.0 Soundbar Black
Poor signal with lg vx8500
LG VX8500 Signal Boosters and Antennas. Keep your cell phone signal strong with these LG VX8500 Antennas for use in your car, office, home, or boat. Get even more from your LG VX8500 cell phone with an external antenna and 3 Watt Signal Booster. Don't get stuck without cell service at a time when you really need it. Add an antenna and booster compatible with your LG VX8500 cell phone.
Nov 26, 2013 | LG VX8550 Cellular Phone
Lg 37le2r will only show black and white picture. Checked antenna ok.
Jan 09, 2010 | LG 37LE2R 37 in. LCD TV
HD50LPW42 screen is black with antenna inputs
It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
I hope that this helps you solve your issue.
Thanks
asnowman
Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Off air antenna hook up
You probably have to set the tv to run on the input jacks your antenna is plugged in to. In other words these newer tv's have 2 or 3 inputs and they only run on the input it is set on, if not the right one you must change the setting. On mine there is a button next to the on/off button on the set which is inputs, keep pressing that button and it cycles through inputs till you get the right one. When tv first comes on it flashes the name of the current input on the screen--think they all do that. If input is hdmi, it refers to the hdmi socket, if composit (I think) then it refers to the rca jacks that are red, white, yellow, may be more than one of either. In this way you could have cable on one input, a video player on another, and cable on still another by switching desired input. I use a UHF antenna but it didn't work till I got the right input and then searched for stations studying the menu for station setup, have to set up the stations first, it will configure settings for each station, and have it do that before you can expect to find and receive stations. With correct input you should get a blue screen or something with printing if input is right, click your menu button and will see the menu and then find where to configure stations setup, otherwise it is totally black and nothing happens, nothing responds, that's the wrong input.
Jan 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
No power
You have the wrong wire hooked up to the 'remote' input on the amp. The remote input waits for a discrete 12v+ signal from the radio. You have the 'power antenna' wire hooked up to the remote input. The power antenna lead shows 12v+ when the radio is on, but as soon as you change the source to CD, the power antenna drops the 12v+ and shuts your amp off. If you're radio has a blue/white wire, use that to turn the amp on instead of the blue wire you are currently using. If there is no blue/white wire, either the radio uses a non-standard color or the radio does not have the necessary wire. In the case that there is no true 'remote' wire, you can get away with using the accessory wire to the radio. That would be the red one. Jump that one over and you'll be running.
May 11, 2008 | Clarion APA2160 Car Audio Amplifier
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
23 people viewed this question
Computer Repairing
Computer Repairing
